Best fuel pump for Webered Six-cylinder, and does it need a return feed? |
Qarl |
Apr 26 2003, 09:17 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Working out the plumbing details for my six conversion for the fuel lines. I've read a few threads and I'm still confused.
I'd like to keep the fuel pump in the front underneath the tank. (The 1975 car I'm staring with had it there to begin with.) What sort of pump should I use to get the 3.5 to 4.5 lbs pressure I need for the Weber 46s? Hardi, Bosch, Rotary, Holley? Do I need a return flow line? If I have a pump that flows at 3.5 lbs, do I need a pressure regulator. I also plan on installing a filter before the pump and one before each carb. Thanks, Karl |
thesey914 |
Apr 26 2003, 10:00 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
A fuel return line is not required for carbs.
Lo-Fi Version | Time is now: 24th May 2024 - 05:10 AM |
