Best fuel pump for Webered Six-cylinder, and does it need a return feed? |
Qarl |
Apr 26 2003, 09:17 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Working out the plumbing details for my six conversion for the fuel lines. I've read a few threads and I'm still confused.
I'd like to keep the fuel pump in the front underneath the tank. (The 1975 car I'm staring with had it there to begin with.) What sort of pump should I use to get the 3.5 to 4.5 lbs pressure I need for the Weber 46s? Hardi, Bosch, Rotary, Holley? Do I need a return flow line? If I have a pump that flows at 3.5 lbs, do I need a pressure regulator. I also plan on installing a filter before the pump and one before each carb. Thanks, Karl |
ChrisReale |
Apr 26 2003, 10:10 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
QUOTE(thesey914 @ Apr 26 2003, 09:00 PM) A fuel return line is not required for carbs. correct, but search around a bit. I seem to recall that some people choose to use a return line for reasons beyond my understanding. |
Lo-Fi Version | Time is now: 24th May 2024 - 10:02 PM |
