Best fuel pump for Webered Six-cylinder, and does it need a return feed? |
Qarl |
Apr 26 2003, 09:17 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Working out the plumbing details for my six conversion for the fuel lines. I've read a few threads and I'm still confused.
I'd like to keep the fuel pump in the front underneath the tank. (The 1975 car I'm staring with had it there to begin with.) What sort of pump should I use to get the 3.5 to 4.5 lbs pressure I need for the Weber 46s? Hardi, Bosch, Rotary, Holley? Do I need a return flow line? If I have a pump that flows at 3.5 lbs, do I need a pressure regulator. I also plan on installing a filter before the pump and one before each carb. Thanks, Karl |
Joe Bob |
Apr 27 2003, 07:18 PM
QUOTE(ginter @ Apr 27 2003, 05:05 PM) QUOTE Or will this not pump enough fuel for my big six? It doesn't matter how big the six is. If you're running carbs you need 3.5 psi. Not as simple as that Mikey.....volume is also involved. If you have REALLY thirsty carbs, you might draw more gas than the pump can deliver. What's to say that a 6 psi rated pump gets regulated down to 3.5 but due to volume the delivery to the carbs is like 2.0...... |
Lo-Fi Version | Time is now: 18th May 2024 - 09:07 AM |
