lmcchesney |
Member ![]() ![]() Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None ![]() |
I replaced the oil pressure sender on the top of my case with a sender which provides light activation and VDO oil pressure reading. How do I know which pole is for the light and which is for the pressure gauge?
The gauge also has three connectors for the gauge (not the connector for the light) which is marked +, G and grnd. What connects to what? Thanks, L. McC |
Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
QUOTE(lmcchesney @ Aug 8 2004, 08:44 AM) Thanks everyone, One thing I picked up was the comment about using teflon tape on the sender may prevent the sender from achiving a ground. On 914's, since you can't mount the sender directly (doesn't fit with the engine tin), you must mount it remotely using a flexible hose as was discussed here. So you cannot achieve a ground connection through the threads anyway (electricity doesn't really like to travel through 12" of rubber hose). You must make sure the body of the sender is grounded - usually through it's mounting bracket. Demick |
DrifterJay |
I break stuff... ![]() ![]() ![]() Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None ![]() |
my engine tin is trimmed...fits nicely.. (IMG:style_emoticons/default/biggrin.gif)
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(DrifterJay @ Aug 20 2004, 09:45 PM) my engine tin is trimmed...fits nicely.. 'course what you've done is mount a big heavy pendulum onto an aluminum boss in a high-vibration area. these have been known to fail when the stress work-hardens the aluminum as it eventually will. but it's nothing a new case won't fix ... there's a reason most people remote mount those... |
Lo-Fi Version | Time is now: 14th July 2025 - 11:36 PM |
