gauge wiring advice, run all new or use existing harness |
machina |
Aug 7 2004, 09:23 AM
installing new oil temp and psi plus tach, speedo and cht/egt.
should I pull the old harness with all the blinker and lighting bulbs which I don't need or should I try to use part of the harness? This is a racecar folks, all those extra wires seems like baggage I don't need. Any reason to keep the old bundle? See unwanted gaggle below. dr Attached image(s) |
Lo-Fi Version | Time is now: 13th May 2024 - 04:08 AM |
