WTB: 914/6 Tach |
WTB: 914/6 Tach |
madd_dogg_914 |
Apr 27 2003, 10:06 PM
Member Group: Members Posts: 478 Joined: 30-March 03 From: Vacaville, CA Member No.: 497 Region Association: Northern California |
Nope that one failed too! Hey Brad, I tried, I really did, but it looks like fate has something different in mind for the BBS members (Big Ass Boobies!!!)
-Chris p.s. I will try again tomorrow |
Brad Roberts |
Apr 27 2003, 10:07 PM
You have to remove it... then replace it.
B |
Lawrence |
Apr 27 2003, 10:13 PM
QUOTE Do I dare ask if you "tested" with the permatune after getting it running correctly ?? This will rehash what's been posted to Rennlist. Long story, but yes. In short: 1. Put in Permatune - not at all driveable, but replaced many parts on the advice of PT tech support. No lightshow in the engine bay at night. 2. Put in a stock unit - drove 300 miles to Iowa. 3. While in Iowa, put in Permatune. 4. Couldn't make it two blocks. 5. Put stock unit back in, drove home. 6. Got rid of the Permatune. 7. Cleaned, adjusted, etc various parts of car. But my car runs well now, and I'm a very happy camper. -Rusty |
madd_dogg_914 |
Apr 27 2003, 10:16 PM
Okay, now it is done. I will try to have more boobies soon fellow teeners (I will just cover them up a little bit first)
-Chris |
Brad Roberts |
Apr 27 2003, 10:21 PM
Sorry you had a bad experience LB. Just for fun... the Permatune I used was marked bad..but I decided to test it anyway..because I didnt recall marking it bad. It worked fine. Did you tell Permatune to shove it up their ass ?
B |
meursault |
Apr 27 2003, 11:03 PM
Idjit Savant Group: Members Posts: 290 Joined: 26-February 03 From: San Diego, CA Member No.: 355 |
Lawrence-
Beore springing for another tach, are you sure you checked everything between the distributor and the gauge? On an original six there's at least one relay on that wonderful relay board in the engine compartment to complicate the circuit. I think its purpose is to reduce voltage going to the tach for a more accurate reading. Without this speed sensor or whatever it's called to complete the circuit, your tach won't work. If you bypass it, you may fry the tach. Or maybe not. Someone explained this to me years ago, so maybe this is inaccurate information. Somebody wish to corroborate this story or refute it? |
Lawrence |
Apr 28 2003, 06:24 AM
Good morning, Mersault,
The item you're referring to is the ballast resistor on the relay board. I'm pretty sure mine is okay. A new ballast resistor is about the same price as a good used /6 tach. I may have a line on borrowing a couple of spare parts to help troubleshoot. Can someone tell me about PA Speedo vs. Hollywood? Any difference in quality, service, price? -Rusty |
elmonte |
Apr 28 2003, 04:42 PM
Member Group: Members Posts: 225 Joined: 31-March 03 From: Danville.ca Member No.: 499 |
PA speedo fixed my odo/trip, expensive? $150
vey fast service,2days 70914/6 2.2 |
Lawrence |
Apr 28 2003, 07:20 PM
Was that a repair, or did they repaint the face as well?
-Rusty |
tahoward |
Apr 28 2003, 07:27 PM
Member Group: Members Posts: 87 Joined: 30-December 02 From: Middletown, OH Member No.: 52 |
N Hollywood re-calibrated my tach, fixed my trip odometer, repaced all three plastic lenses with glass and then put new bezels on all for $220. Quick turnaround and they look and work great.
markb |
Apr 28 2003, 09:51 PM
N Hollywood rebuilt the speedo in the blue car & it works great. The shop sends everything to them and I've yet to hear of a bad one.
Jeffs9146 |
Apr 28 2003, 10:00 PM
I used N. Hollywood 20 years ago! Wow they are still around! They did a great job on my old car!
Jeff Attached image(s) |
elmonte |
Apr 28 2003, 10:32 PM
QUOTE(Lawrence @ Apr 28 2003, 05:20 PM) Was that a repair, or did they repaint the face as well? -Rusty that was a repair & calibrate $90 in labor and $59 in parts UPS and tax |
Lo-Fi Version | Time is now: 26th April 2024 - 01:59 AM |
