| TheCabinetmaker |
Nov 16 2011, 02:46 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Now that I am looking at member numbers, have you noticed yours, vsg914? Or shall I say SATAN? (IMG:style_emoticons/default/happy11.gif) Fate? Some here will say i wear it well. (IMG:style_emoticons/default/biggrin.gif) |
| Drums66 |
Nov 17 2011, 06:34 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Btw, your timing will not change when the engine warms up. That's correct but, the engine speed changes when it warms-up. Since the timing is checked at certain RPM, it should be checked on a warm engine, especially at idle. Haha. Only the idle speed changes. 3200 rmp is 3200 rpm. hot or cold. (IMG:style_emoticons/default/smile.gif) I will time it cold to get it running well and then again when it warms up. I got the dizzy out, by the way. The plate was hanging up on the tin, but it felt like the drive was hanging up in the shaft. I was very much relieved to see no brass shavings and the drive was indexed right where it is supposed to be. Now, I just need to pop the valve cover to make sure it is tdc for 1, rather than 2. Is there a better way to tell that doesn't involve spilling oil all over my heat exchanger? Is there a better way to tell that doesn't involve spilling oil all over my heat exchanger? Chop Sticks! (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/screwy.gif) What ever happened to him? ............In 914 Limbo,,,,..along with others (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/bye1.gif)(Timing is everythingLOL) |
| Valy |
Nov 17 2011, 08:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Haha. Only the idle speed changes. 3200 rmp is 3200 rpm. hot or cold. (IMG:style_emoticons/default/smile.gif) I will time it cold to get it running well and then again when it warms up. It's a 1.8 L-Jet so the timing is checked at idle or 850RPM (IMG:style_emoticons/default/screwy.gif) |
| Drums66 |
Nov 18 2011, 04:49 PM
(IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/309.gif) (Valy)
Lo-Fi Version | Time is now: 12th October 2026 - 08:09 AM |
