Need two things for 6 conversion |
mack914 |
Aug 9 2004, 06:29 AM
Member Group: Members Posts: 387 Joined: 5-July 04 From: Toledo, Oh Member No.: 2,306 |
I need 2 items to help in my conversion. I have seen pictures and advice given for both, maybe you can help. Need carb linkage setup. Connector for rear shift linkage. Both of these items are aftermarket, just need suppliers names. The connector for the rear shift linkage allows the rear shift rod to be connected to the shift rod coming out of the firewall.
Mack |
Joe Bob |
Aug 9 2004, 09:23 AM
Carb linkage set up....are you going to use the bell crank off of the trans or come in over the top with the cable?
Shifter linkage? Usually you just take the kink out of the rod and use the stock knuckles on both ends.... |
Eric_Shea |
Aug 9 2004, 10:35 AM
Rich Johnson. Listed in the "Resources" section in this thread
Lo-Fi Version | Time is now: 9th May 2024 - 05:10 PM |
