Need two things for 6 conversion |
mack914 |
Aug 9 2004, 06:29 AM
Member Group: Members Posts: 387 Joined: 5-July 04 From: Toledo, Oh Member No.: 2,306 |
I need 2 items to help in my conversion. I have seen pictures and advice given for both, maybe you can help. Need carb linkage setup. Connector for rear shift linkage. Both of these items are aftermarket, just need suppliers names. The connector for the rear shift linkage allows the rear shift rod to be connected to the shift rod coming out of the firewall.
Mack |
Joe Bob |
Aug 9 2004, 09:23 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Carb linkage set up....are you going to use the bell crank off of the trans or come in over the top with the cable?
Shifter linkage? Usually you just take the kink out of the rod and use the stock knuckles on both ends.... |
Eric_Shea |
Aug 9 2004, 10:35 AM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Rich Johnson. Listed in the "Resources" section in this thread
Lo-Fi Version | Time is now: 20th May 2024 - 06:50 AM |
