> Many thanks to SLITS for fixing my water pump situation!, Rare, one-of-a-kind or just an odd ball water pump housing.
BRAVE_HELIOS
post Nov 20 2011, 05:50 PM
"Knowledge speaks, wisdom listens"
...probably the latter.
I ordered a cast cover/cast impeller water pump from Ron. When it arrived, it would not fit in my R.H. water pump housing. Long story short; I ended up sending Ron my housing, my original aluminum/stamped steel impeller water pump and the water pump he sent me. After much inspection and research, he informed me that it's my RH water pump housing that is perhaps an odd ball design. He was very gracious. Not only did he have my original water pump rebuilt (the ceramic seals had failed); he also replaced the stamped steel impellers with cast impellers AND he also sent me a cast cover/stamped steel water pump machined to fit in my houising!
I call this going way above and beyond the call of duty!
Ron performed an excellent feat of customer service and I will never forget this!
I installed my aluminum cover/cast impeller water pump as Ron suggested and it's performing flawlessly!
Thank you Ron!
You are da man!! (IMG:style_emoticons/default/beer.gif)
Eric_Shea
post Nov 20 2011, 06:13 PM
PMB Performance
Rare, one-of-a-kind
Ron is... in a good way. (IMG:style_emoticons/default/wink.gif)
Dr Evil
post Nov 20 2011, 10:16 PM
Send me your transmission!
Ya, you want to hate him, but he is just too damn cuddly (IMG:style_emoticons/default/wink.gif)
- Lo-Fi Version Time is now: 14th May 2026 - 12:47 PM
