over filling oil? and oil leak problem |
Apr 28 2003, 04:47 PM
Group: Posts: 0 Joined: -- Member No.: 0 |
Strange, I finally got the car "streetable" and started driving the car around to make sure everything works. After a few minutes of driving, I noticed a lot of "clean" oil around the shift linkage and the engine mount bar. Where is it coming from? I saw some oil on the engine tin where the cylinders meet the head, but I wiped that off, and drove around, and there is not much on there after driving. Just alot around the linkage and bar area. It would drip when I'm driving too, (I can tell because I see a trail of small drips of oil on the ground.) I checked the oil after the car somewhat cooled down, and it's about 5mm-8mm higher than the top mark.
Any Ideas? I would take a pic, but my camera is jacked up. (damn butter fingers) |
Brad Roberts |
Apr 28 2003, 04:53 PM
Did you pull the flaps out ?? and the little bellows ?? and the little wheel that the cable followed ??
The little wheel had a little bolt.... PUT IT BACK IN THE BLOCK. B |
Apr 28 2003, 05:02 PM
Hmm, yeah I did take the flaps out. Damnit, I knew I would forget something! so the little bolt where the little wheel would go should hold the oil back in? Hahaha!
<--- Moron at work (AKA Honda BOYEEEEE) |
Brad Roberts |
Apr 28 2003, 05:05 PM
The little bolt keeps the oil in the block where it should be...
Dont you wish you could hate me ?? :finger2: B |
Apr 28 2003, 05:06 PM
yeah I hate you. (IMG:style_emoticons/default/finger.gif) If you were closer, I'd come by and hate on you some more. haha
Lo-Fi Version | Time is now: 8th May 2024 - 04:43 AM |
