> Stupid Question, I do not know much but im learning
914curt
post Apr 28 2003, 06:52 PM
This may seem like a dumb question. Do the 914-4 engines use a dry sump oil system? I am looking at getting a nice breather bottle but i don't know if the one on summit racing is what i need because is say's it is for a dry sump system. so can any one let me know please.
Curt
Bleyseng
post Apr 28 2003, 07:03 PM
Aircooled Baby!
914's are wet sump and 914/6 are dry sump.
Geoff
Brad Roberts
post Apr 28 2003, 07:07 PM
914 Freak!
Show us the bottle. Copy the pic of the bottle from their website and paste it here. Or show us a link.
B
914curt
post Apr 28 2003, 07:19 PM
Brad here is the link
http://store.summitracing.com/product.asp?...searchtype=ecat
Lawrence
post Apr 28 2003, 07:22 PM
Nice looking bottle. Wish it had a larger fitting for my stock /6 hoses.
-Rusty
URY914
post Apr 28 2003, 08:50 PM
I'm using the same type made by Jaz Products. Works very well.
post Apr 28 2003, 09:04 PM
Group:
Those work well with my Honduuuhh. They are wet sump systems.
User is offlinePM
Brad Roberts
post Apr 29 2003, 02:23 AM
914 Freak!
Your good Curt... run it. I use the Black JAZ setup on my cars... same thing.
B
ChrisReale
post Apr 29 2003, 10:07 AM
Sleazy
So, would you remove the hose from the "elbow", that comes from the PCV, and stick it in the bottle? Would this be a way to keep the phlenum cleaner?
Brad Roberts
post Apr 29 2003, 12:19 PM
914 Freak!
On a stock injected engine.. I want the engine to pull a vaccuum on itself. This actually frees up a few hp. Make sure you have the hoses going to the correct places. They should all be above the air cleaner (in the top) meaning that the vapor gets filtered before going into the throttle body.
B
Dave_Darling
post Apr 29 2003, 12:30 PM
914 Idiot
B, the air cleaner has very little if any vacuum.
The hose from the PCV valve (that's the one in or next to the oil filler) should go to the manifold, not the air cleaner. If you're getting a lot of oil in the manifold from this, you might want to pick up a new PCV valve. They are evidently available again after a while of being NLA. I have also heard of people putting a restrictor with a small hole into the hose, which probably helps at least some with the oil.
Hmm, maybe running the PCV hose to a separator of some kind, then plumbing the separator to the manifold?? That might be one way to keep the oil out...
--DD
ChrisReale
post Apr 29 2003, 01:24 PM
Sleazy
Im not having any problems with too much oil going in there, I was just curious. Brad, when you say pulling a vacuum on itself, does the stock D-Jet set up do this? My hoses are connected properly. Is there still power to free up by re-routing any hoses?
914curt
post Apr 29 2003, 01:44 PM
I am going to be using this on a car wth carbs. you guys are talking about a car with fi. for my car all i have to do is run the hose from where i put the oil in and hook it to the bottle. is that correct?
Curt
Bleyseng
post Apr 29 2003, 02:19 PM
Aircooled Baby!
They are talking about a car with FI here.
Chris, you want the PVC hose to go to the plenum right next to where the MPS hose hooks up. Thats a strong vacuum to pull the air out of the engine block where it gets pressurized from the blowby and shit flying around in a circle. You want the intake to pull that out and then digest it. By reducing the pressure inside the motor the engine spins easier (a small amount)
Geoff
ChrisReale
post Apr 29 2003, 02:58 PM
Sleazy
Cool, thats the way mine is now. damn, nuthin to tweek (IMG:style_emoticons/default/laugh.gif)
- Lo-Fi Version Time is now: 16th April 2024 - 07:51 AM
