My lightweight project continues, Body work pictures |
URY914 |
Apr 28 2003, 07:56 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,466 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Work is progressing at a snail's pace. I'm currently hanging the body work on the car. Making all the pieces line up is a PITA. I found that I have to get the hood set in it's final position than fit the fenders and doors to it. I'll expain as I go...
The first shot is the hood which is nearly completed showing the "hump" for the instament pod. This would have been easier if I had made the mold for the hump a little better. This took a lot of bondo and sanding to get to look right. Attached image(s) |
URY914 |
Apr 28 2003, 08:09 PM
You can also see in the last picture when you cut out the door hinge, you open up the fender well. So you have to make a stone shield.
This is where the hood meets right side door/fender. I have to add about 3/16th of a inch of f/glass to the door edge to get it to meet tight and close the gap. This is a PITA. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 9th May 2024 - 03:09 PM |
