My lightweight project continues, Body work pictures |
URY914 |
Apr 28 2003, 07:56 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,483 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Work is progressing at a snail's pace. I'm currently hanging the body work on the car. Making all the pieces line up is a PITA. I found that I have to get the hood set in it's final position than fit the fenders and doors to it. I'll expain as I go...
The first shot is the hood which is nearly completed showing the "hump" for the instament pod. This would have been easier if I had made the mold for the hump a little better. This took a lot of bondo and sanding to get to look right. Attached image(s) |
Brad Roberts |
Apr 29 2003, 11:59 AM
Listen to Mueller (all grown up now)
Mr. Suspension now with his roller bearings ... :finger2: The weight savings asscoiated with Muellers list might save you 14 lbs total. Good idea's but a ton of work. You can lighten the front rotors by drilling holes in the flat surface leading up to the actual rotor from the face. You could go with a lightweight caliper.. and save a few pounds. You could also cross drill the current rotors and save a few lbs. Cut the targa bar off and run a Sheridan fiberglass replica. 20+ lbs there. B |
Lo-Fi Version | Time is now: 10th May 2024 - 03:32 AM |
