My lightweight project continues, Body work pictures |
URY914 |
Apr 28 2003, 07:56 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,486 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Work is progressing at a snail's pace. I'm currently hanging the body work on the car. Making all the pieces line up is a PITA. I found that I have to get the hood set in it's final position than fit the fenders and doors to it. I'll expain as I go...
The first shot is the hood which is nearly completed showing the "hump" for the instament pod. This would have been easier if I had made the mold for the hump a little better. This took a lot of bondo and sanding to get to look right. Attached image(s) |
URY914 |
Apr 29 2003, 02:13 PM
The driver's side will be bolted on but the bolts will be small and not visible from the outside. The right side is molded into the door and rocker panel for one big ass piece and will also be held with one hidden bolt, one hood pin and one dzus fastener. This may change as I screw around with the best way to do things.
Paul |
Lo-Fi Version | Time is now: 10th May 2024 - 07:14 AM |
