My lightweight project continues, Body work pictures |
URY914 |
Apr 28 2003, 07:56 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,486 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Work is progressing at a snail's pace. I'm currently hanging the body work on the car. Making all the pieces line up is a PITA. I found that I have to get the hood set in it's final position than fit the fenders and doors to it. I'll expain as I go...
The first shot is the hood which is nearly completed showing the "hump" for the instament pod. This would have been easier if I had made the mold for the hump a little better. This took a lot of bondo and sanding to get to look right. Attached image(s) |
Brad Roberts |
Apr 29 2003, 04:20 PM
You dont have to cross drill the rotors (I dont like it...but you AutoX...not road race) Surface area shouldnt be an issue for you. The holes in the flat surface work very well (the transition part from lug holes to pad surface) Not sure yoif you understand which part I'm talking about.
Roger will sell the targa bar separate. Call him and ask him..tell him Brad sent you. You dont need the inside piece he sells... just the outer targa bar itself. He sells a insert that looks just like the insides of the targa bar. B |
Lo-Fi Version | Time is now: 10th May 2024 - 05:50 AM |
