Steel Flares installed, I have only had them a year now...ahead of schedule |
kfish914 |
Nov 29 2011, 04:12 PM
Member Group: Members Posts: 161 Joined: 7-May 08 From: Osceola, Indiana Member No.: 9,026 Region Association: Upper MidWest |
tscrihfield |
Nov 29 2011, 04:13 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
Nice! Looks good!
TurbOH Brad |
Nov 29 2011, 04:23 PM
Brad. Just Brad. Group: Members Posts: 207 Joined: 2-February 11 From: Sparks, NV Member No.: 12,654 Region Association: Northern California |
I take it you are deleting the front side marker?
The factory M471 GT's that were imported still had them, but I believe they were moved farther forward on the fender, or perhaps the flares were welded further back. Either way, it looks good. |
BajaXJ92 |
Nov 29 2011, 05:10 PM
Extended Member Group: Members Posts: 2,146 Joined: 20-April 06 From: Prescott, AZ Member No.: 5,895 Region Association: MidAtlantic Region |
Awesome! (IMG:style_emoticons/default/beerchug.gif)
bulitt |
Nov 29 2011, 05:35 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Did you butt weld or lap?
Did mine last week also, found lots of bondo and had fitment issues on left rear. Looks good! |
McMark |
Nov 29 2011, 06:55 PM
Please tell me you didn't leave that flap of metal in there. (IMG:style_emoticons/default/yikes.gif)
If so, get your head up in there with a grinder and get it out. Overlapping panels like that will capture water and lead to rusted out fenders. Seam sealer will only work as a band-aid. Once the seam sealer breaks down, it traps water BETTER! Otherwise, nice work! (IMG:style_emoticons/default/cool_shades.gif) |
rick 918-S |
Nov 29 2011, 08:16 PM
Hey nice rack! -Celette Group: Members Posts: 20,436 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Please tell me you didn't leave that flap of metal in there. (IMG:style_emoticons/default/yikes.gif) If so, get your head up in there with a grinder and get it out. Overlapping panels like that will capture water and lead to rusted out fenders. Seam sealer will only work as a band-aid. Once the seam sealer breaks down, it traps water BETTER! Otherwise, nice work! (IMG:style_emoticons/default/cool_shades.gif) (IMG:style_emoticons/default/agree.gif) It's ok to use the overlap method for welding only. This will help with heat warpage. Once your finished get in there and remove the strip of metal, grind everything nicely, use a light on the inside and check for pin holes. |
Socalandy |
Nov 30 2011, 12:25 AM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
very nice, I cant wait to get mine on
bulitt |
Nov 30 2011, 07:07 AM
Please tell me you didn't leave that flap of metal in there. (IMG:style_emoticons/default/yikes.gif) If so, get your head up in there with a grinder and get it out. Overlapping panels like that will capture water and lead to rusted out fenders. Seam sealer will only work as a band-aid. Once the seam sealer breaks down, it traps water BETTER! Otherwise, nice work! (IMG:style_emoticons/default/cool_shades.gif) Whats the best way to seal the welds on the inner side? |
scotty b |
Nov 30 2011, 07:20 AM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Please tell me you didn't leave that flap of metal in there. (IMG:style_emoticons/default/yikes.gif) If so, get your head up in there with a grinder and get it out. Overlapping panels like that will capture water and lead to rusted out fenders. Seam sealer will only work as a band-aid. Once the seam sealer breaks down, it traps water BETTER! Otherwise, nice work! (IMG:style_emoticons/default/cool_shades.gif) Whats the best way to seal the welds on the inner side? I always grind them down smooth just like the outside, but if you opt to leave the bead, at least knock the tops off to level it and apply some primer ( etch then seal, or only use epoxy primer ) then a bead of seam sealer BRUSHED onto the weld. Simply laying a bead out of a caulk tube will leave voids and adhesion will be minimal. You can lay the bead but then follow it up with a small acid brush to get the sealer into the cracks and spread it out a bit. Followed that with a coat of primer and undercoating. All this CAN be done with reattle can products, but would be best with real 2 part paints and a gun. |
kfish914 |
Nov 30 2011, 08:45 AM
Yes, deleted the side marker lights. I had a lot of trouble deciding to remove them but after looking at a lot of pictures I did not like the look of them moved forward and like the cleaner look of the European cars. I may add a small side marker behind the front flares some day.
Yes, we did overlap weld cut out the ribbon of metal behind and ran a weld bead along the inside as well. We then coated with an epoxy primer and will spray with undercoating next. My friend who has done body work for 18 years believes this gives a stronger joint. Right or wrong he did most of the work so I went with his suggestion. We had some fitment issues as well getting the bottoms to fit well. Otherwise the panels went on very well. Looking forward to all the sanding and filling and sanding to get everything baby smooth. Thanks for your responses. Getting flares put on was a 20 year dream of mine. Now if I can figure out the wiring for the 2.7 six I should have this ready to drive in the spring, around here is mid April if we are lucky. |
JMKnight |
Nov 30 2011, 09:30 AM
Aces & Eights Group: Members Posts: 135 Joined: 30-December 09 From: Northern Indiana Member No.: 11,188 Region Association: Upper MidWest |
(IMG:style_emoticons/default/aktion035.gif) REALLY NEET!, maybe I'll se you around the Bend next Summer!!. I'm driving a yellow 914 (IMG:style_emoticons/default/biggrin.gif)
I finally got my flares welded over the Turkey weekend marking the panels the cut out the weld all welded up |
kfish914 |
Nov 30 2011, 12:53 PM
Yeah, I hope to see you also. I was the guy who drove over to pick up the t-shirt. If everything goes well I will be hitting some of the cruise ins in the area. My dad and I try and get out to the Das EssenHaus on their Thursday cruise ins starting in May.
For those that have not seen his yellow one it looks great in person. |
McMark |
Nov 30 2011, 04:30 PM
Awesome! Definitely sounds like you found one of the good guys. (IMG:style_emoticons/default/thumb3d.gif)
Are they headed for paint? |
patssle |
Nov 30 2011, 08:59 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Who's flares are those? And any pics of the rear on?
sean_v8_914 |
Dec 1 2011, 07:55 AM
could you please show us a close up of the bottom joint near the rocker panel?
pdlightning |
Dec 1 2011, 10:44 AM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
could you please show us a close up of the bottom joint near the rocker panel? Very nice! I would like to see those also. Are you using the wide body rockers for those flairs? After completing these, would you overlap them again or butt weld considering all factors. I am still floundering on which way to do mine. |
mepstein |
Dec 1 2011, 11:23 AM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
could you please show us a close up of the bottom joint near the rocker panel? Very nice! I would like to see those also. Are you using the wide body rockers for those flairs? After completing these, would you overlap them again or butt weld considering all factors. I am still floundering on which way to do mine. Factory butt welded. So does Scotty B...(IMG:style_emoticons/default/smile.gif) |
kfish914 |
Dec 1 2011, 09:39 PM
If I were to do it over I would butt weld. Only because of the amount of body work I am looking at this time. I think the butt weld would have given me a smoother starting point.
I went with what he suggested because of his experience, and it was his shop that we did the work in. I know some are thinking it’s my car I should have done it the way I wanted. For me I like the idea of a strong joint and hind sight is always 20/20. The end result is I have the flares welded on with from what I can see a good seem on both the inside and outside of the car. I will be modifying my current rockers to match up with the flares so I get a perfect match. I heard many stories of them not lining up (some times more than an inch and a half) and call me cheap but if I’m going to pay $150 plus for some strips of fiberglass I would expect them to line up better than what I have heard they do. The flares are from the group buy from AA This is what I hope it will look like when all is said and done. I will get those photos once I charge up the camera again. |
partwerks |
Dec 1 2011, 10:17 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Where can I get the front chrome bumper with the notch in it like the black car has?
Lo-Fi Version | Time is now: 3rd May 2024 - 10:25 AM |
