Steel Flares installed, I have only had them a year now...ahead of schedule |
kfish914 |
Nov 29 2011, 04:12 PM
Member Group: Members Posts: 161 Joined: 7-May 08 From: Osceola, Indiana Member No.: 9,026 Region Association: Upper MidWest |
McMark |
Nov 29 2011, 06:55 PM
Please tell me you didn't leave that flap of metal in there. (IMG:style_emoticons/default/yikes.gif)
If so, get your head up in there with a grinder and get it out. Overlapping panels like that will capture water and lead to rusted out fenders. Seam sealer will only work as a band-aid. Once the seam sealer breaks down, it traps water BETTER! Otherwise, nice work! (IMG:style_emoticons/default/cool_shades.gif) |
bulitt |
Nov 30 2011, 07:07 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Please tell me you didn't leave that flap of metal in there. (IMG:style_emoticons/default/yikes.gif) If so, get your head up in there with a grinder and get it out. Overlapping panels like that will capture water and lead to rusted out fenders. Seam sealer will only work as a band-aid. Once the seam sealer breaks down, it traps water BETTER! Otherwise, nice work! (IMG:style_emoticons/default/cool_shades.gif) Whats the best way to seal the welds on the inner side? |
scotty b |
Nov 30 2011, 07:20 AM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Please tell me you didn't leave that flap of metal in there. (IMG:style_emoticons/default/yikes.gif) If so, get your head up in there with a grinder and get it out. Overlapping panels like that will capture water and lead to rusted out fenders. Seam sealer will only work as a band-aid. Once the seam sealer breaks down, it traps water BETTER! Otherwise, nice work! (IMG:style_emoticons/default/cool_shades.gif) Whats the best way to seal the welds on the inner side? I always grind them down smooth just like the outside, but if you opt to leave the bead, at least knock the tops off to level it and apply some primer ( etch then seal, or only use epoxy primer ) then a bead of seam sealer BRUSHED onto the weld. Simply laying a bead out of a caulk tube will leave voids and adhesion will be minimal. You can lay the bead but then follow it up with a small acid brush to get the sealer into the cracks and spread it out a bit. Followed that with a coat of primer and undercoating. All this CAN be done with reattle can products, but would be best with real 2 part paints and a gun. |
Lo-Fi Version | Time is now: 18th May 2024 - 01:46 AM |
