Plumbing Question #2 |
Porsche Rescue |
Apr 29 2003, 08:35 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Now that I have a handle on Weber fuel plumbing, I am moving on to oil vapor hoses. The engine I am installing is my first with carbs. Can someone tell me what the two small open pipes beside the intake manifolds are for? I assume they are on stock FI engine and I just never noticed them.
I believe I need some sort of vapor cannister (have seen one made by K&N). Do I connect it to the plastic nipple at the oil filler and then to the two nipples at the manifolds? Is this a crankcase vent system? Is there a PCV valve needed? By now you can tell that I'm not real sure I know what I'm doing! |
tryan |
Apr 29 2003, 11:20 AM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
my opinion, put filters on each vavle cover or feed them into one breather canister. hook the pvc/plastic nipple at the oil filler to the intake and jet accordingly. it's always good to keep a vacume on the case. (fresh filtered air into the vavle covers. nasty blow-by gets sucked into the intake.)
i hate gas fumes. i would hook up the charcoal canister as close to stock as possible. most have three connections. the tank. leave this one alone. the air filter/ breather .you will need to have a barbed fitting on the breather/air filter that will not get in the way of your linkage. either side. make sure the hoses are not rotten in the fender wells or rocker panels. a vacume connection that will purge the vapors while the engine is running ( alot of people just disconnect this stuff, but gas fumes kill me. i'm a diesel lover (IMG:style_emoticons/default/biggrin.gif) ) |
Lo-Fi Version | Time is now: 16th May 2024 - 11:33 PM |
