Plumbing Question #2 |
Porsche Rescue |
Apr 29 2003, 08:35 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Now that I have a handle on Weber fuel plumbing, I am moving on to oil vapor hoses. The engine I am installing is my first with carbs. Can someone tell me what the two small open pipes beside the intake manifolds are for? I assume they are on stock FI engine and I just never noticed them.
I believe I need some sort of vapor cannister (have seen one made by K&N). Do I connect it to the plastic nipple at the oil filler and then to the two nipples at the manifolds? Is this a crankcase vent system? Is there a PCV valve needed? By now you can tell that I'm not real sure I know what I'm doing! |
Porsche Rescue |
Apr 29 2003, 11:41 AM
Tryan, thanks, but can we keep it a little more simple.
1.What are the two open tubes at the heads for? Air/fumes in or air/fumes out? 2. The plastic nipple at the oil filler is crank case vent? Is it related to the tubes at the heads? I really don't want to vent the case into my carbs, and I don't see a connection on them anyway (Weber 40 idf). |
Lo-Fi Version | Time is now: 16th May 2024 - 09:23 PM |
