New KB Piston Question, My new set came with two rings- why? |
tornik550 |
Dec 3 2011, 08:11 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I just got a new KB 96mm piston (I had to replace one damaged piston). The new piston came with two rings that are just a little thicker than the oil rings- they have a dimple on one side. The grove in the piston where the oil rings sit is wider than my older set. The new piston also doesn't have the oil ring locating pin.
What are the rings that came with the piston for? |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:41 PM |
