what grease for TO bearing, synthetic OK? |
machina |
Aug 15 2004, 11:02 AM
What's the best thing to use when assembling the clutch? Areas such as the tube, plastic guides, etc.
I have some blue Mobil 1 synthetic grease. Is that OK or should I get some Moly type grease? dr |
Brad Roberts |
Aug 15 2004, 11:45 AM
The Mobil1 is fine, but you should only put *some* on the guide tube for the throwout bearing. The plastic bushing's dont need anything. Grease attracts dirt... dirt wears the guides VERY fast. I dont recall anywhere in the factory manuels where it says: GREASE the bushings.
B |
machina |
Aug 15 2004, 12:53 PM
QUOTE(Brad Roberts @ Aug 15 2004, 01:45 PM) The Mobil1 is fine Thanks brad, Back to work now. (IMG:style_emoticons/default/smash.gif) dr |
Lo-Fi Version | Time is now: 7th May 2024 - 09:06 AM |
