915 tranny question, hydraulic or cable...benefits of each? |
nine14cats |
Aug 15 2004, 11:50 AM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
what are the pro's and con's to a dydraulic clutch versus a cable in a 915 in our cars?
Thanks, Bill P. |
Brad Roberts |
Aug 15 2004, 11:56 AM
If you have the ability to run a stock pedal assembly.... run a cable. If you have bottom swing or top swing Tiltons.. then you have to run a hdy. clutch.
I'm not convinced hyd is the way to go. It works well when you have a Monster pressure plate and need less pedal effort.. but if I had my choice... cable. Easier to deal with at the track if something goes wrong. B |
Britain Smith |
Aug 15 2004, 12:20 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Here is the hydraulic TO bearing...WEVO set-up on the tube car. If you go this route, you have to fab a stop plate behind the pedal because the travel is only about 2 inches to engage/disengage. This unit is basically on/off, takes some time to get used to.
-Britain Attached thumbnail(s) |
Brad Roberts |
Aug 15 2004, 12:24 PM
Save the money and run a stock Throwout bearing. The main reason that is in place: the WEVO 5.5 clutch setup and the car doesnt have a clutch tube for a cable... it was already Hyd.
B |
Britain Smith |
Aug 15 2004, 12:29 PM
You mean this clutch set-up...this is one bad-ass Mo-fo. Talk about throttle response.
nine14cats |
My thoughts are the same...I would like to just run a cable for simplicity...I'm going to run a "stock" type pressure plate and certerforce clutch....in fact...it's sitting here next to me....it sure is pretty (IMG:style_emoticons/default/wub.gif)
I was just checking my thinking.... B, How long would it take to plug my drivetrain into the car if I give it to you/HPH to do? I'm talking drivetrain and full oil cooler assembly including hoses....I've got all of the parts on my shelf already.... I need ballpark hours...I know the rates.... Spreadsheet is calculating.... (IMG:style_emoticons/default/barf.gif) Bill P. |
Brad Roberts |
Aug 15 2004, 12:41 PM
I would do it after hours to help offset the cost. Your looking at 10-12 hours. The fuel pump..high pressure lines..wiring/mounting..
I would work something out with you no matter which direction you take. B |
Walter |
Aug 16 2004, 01:57 AM
Member Group: Members Posts: 70 Joined: 10-August 04 From: The Netherlands, Europe Member No.: 2,499 |
QUOTE(Britain Smith @ Aug 15 2004, 10:20 AM) Here is the hydraulic TO bearing...WEVO set-up on the tube car. If you go this route, you have to fab a stop plate behind the pedal because the travel is only about 2 inches to engage/disengage. This unit is basically on/off, takes some time to get used to. -Britain Is there any other manufactorer that supplies hydraulic throw-out bearings for the 915 box that engage more gentle? I need one for a street car. (The slave cylinder (make: CNC) I have now is very difficult (space restrictions) to attach to the clutch arm...) Thanks! Walter |
bondo |
Aug 16 2004, 09:37 AM
QUOTE(Walter @ Aug 16 2004, 12:57 AM) QUOTE(Britain Smith @ Aug 15 2004, 10:20 AM) Here is the hydraulic TO bearing...WEVO set-up on the tube car. If you go this route, you have to fab a stop plate behind the pedal because the travel is only about 2 inches to engage/disengage. This unit is basically on/off, takes some time to get used to. -Britain Is there any other manufactorer that supplies hydraulic throw-out bearings for the 915 box that engage more gentle? I need one for a street car. (The slave cylinder (make: CNC) I have now is very difficult (space restrictions) to attach to the clutch arm...) Thanks! Walter From what I know about hydraulic clutches (I managed to put together a working setup on my 67 mustang with a 5 speed trans after 3 redesigns) you can get a more gentle engagement by varying the size of the master cylinder (diameter). If you find out what diameter the piston of Britain's master cylinder is, and then get one that has half the area, you'd get 4 inches of travel instead of two. (Half the volume of fluid pumped per inch of pedal travel) Of course this is only if you use Britain's clutch, a "normal" clutch may be different. |
Brad Roberts |
Aug 16 2004, 11:09 AM
In this case.. Britain didnt know exactly what he was talking about... the Tilton 5.5 clutch is the ON/OFF switch not the throwout bearing setup. This particular unit (nobody else makes one for the Porsches besides WEVO) only works with push center pressure plates. WEVO also has one for the 901 gearbox. This one is in a 915.
B |
Lo-Fi Version | Time is now: 7th May 2024 - 09:02 AM |
