Throwout bearing Guide Tube, How do you know if it needs replacing? |
mack914 |
Aug 16 2004, 08:48 PM
Member Group: Members Posts: 387 Joined: 5-July 04 From: Toledo, Oh Member No.: 2,306 |
Throwout bearing is a little sloppy on the guide tube of the replacement trans that I just bought. Is the fact that there is play a reason to replace the guide tube? I will be installing a new throwout bearing. What about the guide tube?
Other ? Can I use the clutch cable that is in my 914 for the 6 conversion that I'm doing? Parts #s indicate that the clutch cable is different for the 914-6. Thanks (IMG:style_emoticons/default/boldblue.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 07:48 AM |
