Part # Verification for Mahle 2.2S Pistons, can someone help me out on this? |
seanery |
Aug 19 2004, 08:18 AM
Mahle PN 503-39-90
Can someone confirm the p/n listed above or point me to a place where I can do it? Thanks! (IMG:style_emoticons/default/smile.gif) |
ArtechnikA |
Aug 19 2004, 09:10 AM
THE source for Mahle in the US is ANDIAL.
but i bet the guys at EBS could help too if you didn't want to deal with ANDIAL directly. |
seanery |
Aug 19 2004, 09:25 AM
pics 1:
seanery |
Aug 19 2004, 09:26 AM
pic 2
seanery |
pic 3
seanery |
pic 4
ArtechnikA |
Aug 19 2004, 09:31 AM
those look like they could be 2,2S pistone.
my E pistons are still powering the car so i can't show you a verified E piston for comparison. i think you'll need to know the pin height before you can conclusively determine that they're -not- 2,4S pistons - the 2,4 was a stroker 2,2 - identical 84mm bore ... but the pin heights in the pistons is different to accommodate the longer stroke... |
seanery |
Aug 19 2004, 11:08 AM
The seller just sent this to me:
QUOTE I E-mailed mahle a while back and the original use was for a 1969 2.2S and they could be used on a 2.4 MFI, they don't use these #'s any more |
ArtechnikA |
Aug 19 2004, 11:29 AM
QUOTE(seanery @ Aug 19 2004, 09:08 AM) QUOTE I E-mailed mahle a while back and the original use was for a 1969 2.2S and they could be used on a 2.4 MFI, they don't use these #'s any more well - that's not helpful - there were no 2,2's in '69 ... and all 2,4 E's and S's were MFI engines. and all 2,2's and 2,4's were 84mm bore... i haven't seen enough of both to be able to eyeball the difference between an E piston and an S -- especially if we don't know whether it's a 2,2 or a 2,4 piston (2,4 engines had significantly reduced compression ratios compared to the 2,2's ...) you need the pin height. i don't know if pin height is referenced to the piston deck, crown or the bottom of the skirt (crown or deck, i'd think...) and i don't know what they measure (the difference) between a 66mm stoke 2,2 and a 70,4mm stroke 2,4 -- but someone here must. or call EBS ... |
seanery |
Aug 19 2004, 12:03 PM
I plan on calling EBS, sending the 2.0 -4 heads there.
The seller has sent an email to Mahle for confirmation, too. |
J P Stein |
Aug 19 2004, 12:37 PM
I once had a set of 2.4L S P/Cs.......plan D or sumthin'.
Those aren't them. The valve pockets & domes were much smaller.....still, check em' out. The only place I know of to find the dimensions would be a factory manual. Andial would have the old P/Ns, I would think. They do have a website listing P/Cs. |
seanery |
Aug 19 2004, 01:10 PM
Andial has a set in stock $2591 (IMG:style_emoticons/default/blink.gif) but it doesn't show the Mahle P/N.
seanery |
Aug 19 2004, 01:14 PM
i wonder how much a good 2.4 crank is?
any other differences between a 2.4 and 2.2? |
Cap'n Krusty |
Aug 19 2004, 02:01 PM
503-45-90 is a 2.2T, FWIW The Cap'n
J P Stein |
Aug 19 2004, 02:04 PM
QUOTE(seanery @ Aug 19 2004, 11:14 AM) i wonder how much a good 2.4 crank is? any other differences between a 2.4 and 2.2? I sold one.....crank & rods for 400 bucks..... I have another on the shelf (& 5 and a half rods (IMG:style_emoticons/default/biggrin.gif)) , but wanna keep it. It works for a 2.7. You'll need rods, also. AIR, they are 1 mm shorter than 2.2 rods. If those are 2.2 pistons, they are "iffy" for a 2.4L.....case clearance & compression (hi) probs. 2.2S is good for 180 hp....minus maybe 10hp with carbs. S cams & Webers are iffy also....for a street motor. Tom Wilkinson had Rothsport build him a 2.5L long storke motor with carbs. AIR it made 196 hp at the crank. He'd be a good man to talk at. He's here somewhere. |
Cap'n Krusty |
Aug 19 2004, 02:09 PM
Good cranks go for 500-750. T cranks may be lower, E/S counterweighted cranks may be higher. The rods and rod bolts are different, and the rod bearings. I believe 2.4 cases are squirted, pretty sure 2.2s aren't. You can use a 2.7 crank in a 2.4, and a 2 litre crank in a 2.2. I have some of each in my pile of engine stuff, as well as some cases of various types. HTH, The Cap'n
ArtechnikA |
QUOTE(seanery @ Aug 19 2004, 11:10 AM) Andial has a set in stock $2591 (IMG:style_emoticons/default/blink.gif) and people think we're kidding when we tell them it's as expensive to rebuild a 2,0 as a 3,0 ... |
seanery |
Aug 19 2004, 02:10 PM
I was just thinking if I bought 'em and they were 2.4 P/Cs.
The plan is E cams with weber 40s. EBS said they'd port the heads to S spec. |
seanery |
Aug 19 2004, 02:11 PM
I've been offered the set pictured for $1200.
ArtechnikA |
Aug 19 2004, 02:16 PM
QUOTE(Cap'n Krusty @ Aug 19 2004, 12:09 PM) I believe 2.4 cases are squirted, pretty sure 2.2s aren't. all the references say squirters started with '70 production, with the 2,2's... i don't have my engine open yet to verify. i think i read something about a main bearing width difference between the 66mm and 70,4mm stroke cranks, but i can't recall where i read it, now ... |
Lo-Fi Version | Time is now: 19th May 2024 - 08:36 AM |
