Part # Verification for Mahle 2.2S Pistons, can someone help me out on this? |
ArtechnikA |
Aug 19 2004, 02:24 PM
QUOTE(seanery @ Aug 19 2004, 12:10 PM) The plan is E cams with weber 40s. EBS said they'd port the heads to S spec. i'm debating that very thing, i wonder if it's needed with the E cams - they have much less lift and duration than the S. T/E/S all had the same valve sizes; i wonder if you'd actually lose port velocity increasing area without a cam change ... |
J P Stein |
Aug 19 2004, 02:31 PM
QUOTE(Cap'n Krusty @ Aug 19 2004, 12:01 PM) 503-45-90 is a 2.2T, FWIW The Cap'n FWIW indeed. Those aren't T cylinders....... (IMG:style_emoticons/default/confused24.gif) Some box swapping? |
J P Stein |
Aug 19 2004, 02:33 PM
QUOTE(ArtechnikA @ Aug 19 2004, 12:24 PM) QUOTE(seanery @ Aug 19 2004, 12:10 PM) The plan is E cams with weber 40s. EBS said they'd port the heads to S spec. i'm debating that very thing, i wonder if it's needed with the E cams - they have much less lift and duration than the S. T/E/S all had the same valve sizes; i wonder if you'd actually lose port velocity increasing area without a cam change ... Solex cams are bout half way between the E & S. You'll never guess what I used (IMG:style_emoticons/default/biggrin.gif) |
Cap'n Krusty |
The main bearings have the same part number through 1974, leading me to believe they're the same size. The Cap'n
seanery |
Aug 19 2004, 02:43 PM
my cam chart
Attached File(s) 2.2_cams ( 72.18k ) Number of downloads: 0 |
seanery |
Aug 19 2004, 02:46 PM
Cap'n I missed your p/n post earlier.
Thanks, looks like we know we're in the ball park. |
ArtechnikA |
Aug 19 2004, 02:49 PM
QUOTE(Cap'n Krusty @ Aug 19 2004, 12:33 PM) The main bearings have the same part number through 1974, leading me to believe they're the same size. The Cap'n you are correct - i found where i read that - it was the rod bearings - the journal was reduced in diameter and increased in width to keep the bearing area the same. the same reference (Anderson 1) says "through 1970" didn't have squirters but they started in '71 -- so it looks like later 2,2's had 'em, and early ones didn't... i plan to run forged pistons, so my engine is getting the uprated Turbo squirters whether it's got any now or not... |
J P Stein |
Aug 19 2004, 02:59 PM
Where were youz guys when I was offloading all my 2.4L engine bits....cheep.
5r case (nice) crank/rods (perfect) non injected heads yada, yada.....your timing sux. (IMG:style_emoticons/default/laugh.gif) Still have T cams iff'n ya need em'......nobody wants those. (IMG:style_emoticons/default/biggrin.gif) I still have a collection of misc. bits, so get aholt of me first if you have needs. |
ArtechnikA |
Aug 19 2004, 03:01 PM
QUOTE(seanery @ Aug 19 2004, 12:43 PM) my cam chart those are 2,0 cam numbers... your first column should read "intake lift at overlap TDC" (the cam timing spec ...) that's the same for 2,0 and 2,2 cams. the events are different for 2,2's tho... T E S intake opens 15* BTC 20*BTC 38* BTC intake closes 29* ABC 34* ABC 50*ABC exhaust opens 41* BBC 40* BBC 40* BBC exhaust closes 5* BTC 6* ATC 20* ATC actually - it looks like T and S are the same, but the 2,2E cam got hotter... |
J P Stein |
Aug 19 2004, 03:20 PM
What is not shown here is lobe centers. Generally, the closer the lobe centers, the more overlap.
Lobe centers for the S is 97 deg (int to exh) Solex is 97 deg E is 102. AIR, the intake lift at overlap for the Solex is 4.0-4.3. The lift and duration is about the same as the E cams. |
seanery |
Aug 19 2004, 03:37 PM
Since I haven't actually disassembled this motor I have a question about cams & bearings.
Webcam lists 3 and 4 bearing cams, when did this change occur? |
ArtechnikA |
Aug 19 2004, 03:44 PM
QUOTE(seanery @ Aug 19 2004, 01:37 PM) Webcam lists 3 and 4 bearing cams, when did this change occur? 1978 |
seanery |
Aug 19 2004, 04:09 PM
ok, so all the 2.0-2.7 production motors are 3 bearing, correct?
ArtechnikA |
Aug 19 2004, 04:14 PM
QUOTE(seanery @ Aug 19 2004, 02:09 PM) ok, so all the 2.0-2.7 production motors are 3 bearing, correct? i didn't see anything that came right out and said so, but that is my inference, yes. i have been led to believe the 4-bearing cam boxes can be used on early cases but i haven't personally checked it out. but i THINK i recall having seen references to people with pre 3,0 engines using GE-billet cams, and AFAIK those were all made on 4-bearing billets. so - i donno how they did it *exactly* but there are many hints... |
seanery |
Aug 19 2004, 04:26 PM
what I've read in the BA text infers that the later cam towers can be used.
Now I know what I need to ask for- If I get Webcam ground cams. |
ArtechnikA |
Aug 19 2004, 04:34 PM
QUOTE(seanery @ Aug 19 2004, 02:26 PM) Now I know what I need to ask for- If I get Webcam ground cams. WebCams are good cams. i was planning on using GE-60 with my 2,8 but i think i'll just continue to use the E-cams with the 2,2+ -- as long as they check out. if there are wear issues, i'll have to revisit the whole issue again... |
Eric_Shea |
Aug 19 2004, 04:53 PM
Those look like 2.2/2.4 S pistons.
At $1200.00 Buy them. I have a 2.4 T crank you can buy. 4 bearing cam housings don't fit earlier engines (me has been told... could be wrong). |
seanery |
Aug 19 2004, 05:04 PM
Eric, is there a difference between the 2 (2.2 and 2.4)?
ArtechnikA |
Aug 19 2004, 05:51 PM
QUOTE(seanery @ Aug 19 2004, 03:04 PM) Eric, is there a difference between the 2 (2.2 and 2.4)? more reading (i should be working ...) Anderson(1) reports the 2,4 piston used the same pin height (so that won't help to know...) but material was removed from the crown to reduce the compression ratio and account for the stroke difference. and JP's weighed in that the pistons in the picture aren't 2,4 pistons. so the question is - are they 2,2E or 2,2S ? i don't know that i've seen anyplace with all the pistons lines up together for identification purposes ... based on the picture that's identified as being a 2,0 S piston, i'd hafta say that looks pretty darned close. if it's a "buy or not" decision, it sounds like the price is right, and even if it turns out they're not exactly what you want, you've got a good enough deal that you can resell them and come out okay ... |
seanery |
Aug 19 2004, 06:25 PM
That sounds like a pretty good consensus.
I'm gonna offer him a grand (just cause I'm a dick) to see if I can get an even better deal! |
Lo-Fi Version | Time is now: 19th May 2024 - 10:23 AM |
