what did you do to your 914 today |
mrbubblehead |
Dec 17 2011, 08:07 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start, about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today? yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup. what did you do to your 914 today? |
Gustl |
Dec 18 2011, 12:27 AM
914 enthusiast & historian Group: Members Posts: 11,487 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
yesterday I put my original leather steering wheel out of the car and replaced it with a newly leather covered one on a 30 mm longer hub (that gives me more leg space; I'm 6 ft 3")
today I will put out the "very custom" permatune installation out of the car and replace it with the original and newly rebuilt Bosch HKZ after this I will set the car in hibernation mode (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 05:07 AM |
