what did you do to your 914 today |
mrbubblehead |
Dec 17 2011, 08:07 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start, about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today? yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup. what did you do to your 914 today? |
ewdysar |
Dec 29 2011, 01:14 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
My newly restored rear brake calipers (Ferrari 308) along with a bunch of other brake parts, got drop shipped by Mr Shea at PMB to Sean at SD Autosport where they will wait to go onto the car.
Nice work Eric! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/beerchug.gif) You should have seen what these calipers looked like before Eric started working his magic... Attached thumbnail(s) Attached image(s) |
reharvey |
Dec 29 2011, 01:38 PM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
My newly restored rear brake calipers (Ferrari 308) along with a bunch of other brake parts, got drop shipped by Mr Shea at PMB to Sean at SD Autosport where they will wait to go onto the car. Nice work Eric! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/beerchug.gif) You should have seen what these calipers looked like before Eric started working his magic... Wow! Nice work! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 28th March 2024 - 11:53 PM |
