what did you do to your 914 today |
mrbubblehead |
Dec 17 2011, 08:07 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start, about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today? yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup. what did you do to your 914 today? |
chandler1969 |
Dec 29 2011, 01:45 PM
Member Group: Members Posts: 112 Joined: 2-January 06 From: Georgetown, Ky Member No.: 5,352 Region Association: None |
Jumped started the car as the cold weather drains the battery so I could drive it to work today (in the 50s today). I need to stop being a cheap a$$ and buy a much better battery.
Lo-Fi Version | Time is now: 10th May 2024 - 08:42 PM |
