877 Pages V « < 875 876 877
TJB/914
post Jul 19 2025, 09:51 AM
Post #17521
Mid-Engn.
New Tires 195x65x15 that fit perfect. I n my opinion this size tire compliments our 914 factory look (IMG:style_emoticons/default/pray.gif)
Also washed it first time since last year, dirt & grime gone. (IMG:style_emoticons/default/w00t.gif)
Tom, on the road finally.
Geezer914
post Jul 19 2025, 03:33 PM
Post #17522
Geezer914
QUOTE(ClayPerrine @ Jul 17 2025, 07:48 AM) *
QUOTE(zulu33 @ Jul 17 2025, 04:15 AM) *
V-belt replacement
After my original V-belt had been doing its job since 1993, it was time to replace . I knew it was going to be bad. Removal was easy, special tools were still there but the belt was not longer available. Finally I found one and off I went. After a few setbacks, one shim fall into the engine mount, but it worked. 9,5x710
cheeRS
Dirk
Suggestion: Changing the belt is much easier with the engine out. Drop the motor and do a valve adjustment and belt replacement at the same time. You get an oil change thrown in for free. Plus, you get to re-torque the CV joint bolts and inspect the shift linkage bushings for deterioration.
This is a once a year task for me.
Fan belt is too narrow, sitting to deep in the pulley!
7 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
1 Members: zulu33
- Lo-Fi Version Time is now: 20th July 2025 - 12:20 AM
