889 Pages V « < 882 883 884 885 886 > »
cassmcentee
post Nov 15 2025, 12:50 PM
Post #17661
Played around...
fiacra
post Nov 15 2025, 02:17 PM
Post #17662
Person.Woman.Man.Camera.TV. = MCI
QUOTE(cassmcentee @ Nov 8 2025, 11:41 AM) *
flushed the break in oil, replaced, ran to the Auto Club to pick up Ruby's new plates... (IMG:style_emoticons/default/biggrin.gif)
@cassmcentee
Looking great Cass. I'm glad Ruby found a home with you.
930cabman
post Nov 15 2025, 02:57 PM
Post #17663
QUOTE(swood @ Nov 4 2025, 11:40 PM) *
Dropped it off for a heart transplant (IMG:style_emoticons/default/driving-girl.gif)
Among other things.
Sweet, hoping I can get my Palma Green example looking as good (IMG:style_emoticons/default/beerchug.gif)
Shivers
post Nov 15 2025, 03:41 PM
Post #17664
Shivers
post Nov 16 2025, 10:24 AM
Post #17665
I like this better
cassmcentee
post Nov 16 2025, 12:07 PM
Post #17666
QUOTE(Shivers @ Nov 16 2025, 11:24 AM) *
I like this better
That does look good!
JmuRiz
post Nov 16 2025, 04:58 PM
Post #17667
What’s your go-to punch & flare tool? I’m thinking about doing that on some stuff and suggestions for new tools are always appreciated
fixer34
post Nov 16 2025, 05:43 PM
Post #17668
QUOTE(Shivers @ Nov 16 2025, 10:24 AM) *
I like this better
These look cool, but I don't quite understand why you would do it. I always thought the inside brake shield was to prevent water, rocks, debris, etc from getting to the inside rotor surface.
Shivers
post Nov 16 2025, 06:01 PM
Post #17669
QUOTE(JmuRiz @ Nov 16 2025, 02:58 PM) *
I use these simple dies, which I got off of Amazon and a harbor freight stand up press.
https://www.amazon.com/UTVDistribution-Piec...t/dp/B079MNQVQN
Shivers
post Nov 16 2025, 06:16 PM
Post #17670
QUOTE(fixer34 @ Nov 16 2025, 03:43 PM) *
I like this better
Disk brakes by design are self cleaning, it’s a stone guard for sure. The biggest hole is 1”, that is a fairly small stone to worry about rotor damage. One thing I’ve noticed is a lot of brake dust gets caught inside the guard, i had to use a scraper to clean it. I would think that the brake dust would disperse like it does on the front. Probably would if it had any air flow, so where is the rotor cooling coming from? And that is the reason I did this. A lot of people just leave them off but I liked this better for the protection. Might have shaved a few grams in the process.
TRP
post Nov 16 2025, 08:48 PM
Post #17671
Today I managed to get the interior all back in, hooked up the new speed-o cable, nstalled the new gearshift lever from JWest, and adjusted the shifter close to final position.
Maltese Falcon
post Nov 16 2025, 11:26 PM
Post #17672
Straight Outta' the Box, added this new 'SteamWheel to the Six. The old Parker Hanaffin served its time as boost controller (IMG:style_emoticons/default/biggrin.gif)
Patrick_139
post Nov 23 2025, 11:05 PM
Post #17673
I managed to locate all of the bulbs that are used for illumination on the gauges and replace them with LED bulbs. I didn't bother with warning or indicator lights. I just want to see better at night even though I don't drive much in the dark. The photograph shows them brighter than they actually are, but they are much better than before.
I also attached a photo showing the original bulb, the LED that did not work (Too short?) and the LED that did work.
mgp4591
post Nov 23 2025, 11:38 PM
Post #17674
Installed a fuel pressure guage.
emerygt350
post Nov 25 2025, 07:27 AM
Post #17675
Time for a long winter nap.
SKL1
post Dec 9 2025, 09:21 PM
Post #17676
Can't believe this thread was on page 6!!
My early '71 got moved into the shop to start its restoration!! Small shop in Iowa near my hometown which mainly does 356's that go all over the world. They did my '73 11 years ago (and it was in a story about them in 000 a few years ago!)
Had the car since new in 11/70. Converted all the suspension to 6 specs back in the early '80's, so now the 6 engine/ tank etc will be fitted...
Feel like a kid on Christmas morning!Attached Image
Cairo94507
post Dec 10 2025, 07:56 AM
Post #17677
Michael
That is very cool. Please post pictures of the process so we can all enjoy the work being done. (IMG:style_emoticons/default/beerchug.gif)
Steve
post Dec 11 2025, 09:44 AM
Post #17678
Replaced 100 amp circuit breaker with a 150 amp circuit breaker. The 100 amp breaker went off at around 60 amps with my electric AC compressor. The 150 amp breaker goes off around 105 amps. My electric AC draws between 45-65 amps. Pays to read the reviews on Amazon when buying this cheap crap. I also couldn’t figure out why my clutch was stiffer with the 3.6 versus the 3.2. Turns out I made the bend to tight with the clutch cable under the car. Removed the clamp on the motor and had my daughter push the clutch pedal to see where the cable wanted to go. Secured the cable at that position. Much better now. Same now as the 3.2. Live and learn….
Cairo94507
post Dec 16 2025, 10:31 AM
Post #17679
Michael
Went and filled the tank after the run down to EASY for the Christmas Toy Drive on the 6th. Parked her back in the garage next to the "Orca".
SKL1
post Dec 16 2025, 11:31 AM
Post #17680
Nice garage Cairo- yep the 991 turbo S is the best "sleeper" supercar out there. Most people just think it' another 911, yawn, but we know better!!
73 User(s) are reading this topic (73 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 4th March 2026 - 12:33 AM
