| Dasnowman |
Sep 26 2012, 11:04 PM
You miss 100% of shots you don't take! ![]() ![]() Group: Members Posts: 265 Joined: 24-May 12 From: Tricities, B.C./ Lake Whatcom Member No.: 14,477 Region Association: Canada |
Spent 3+ hours cleaning the garage Yesteraday... Just to spend a few hours doing some prep work and some primering! lol is that even a word so tired making shit up!
| JoeSharp |
Sep 28 2012, 12:30 PM
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
I moved it into the trailer and the NARB came into the shop. Now there no cars in my yard. Does that mean I am no longer a Redneck?
| euro911 |
Sep 28 2012, 12:43 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
WTF is a NARB? ... The V-twin?
A cute little On-Trac girl delivered a set of Pirelli P4s here this morning (IMG:style_emoticons/default/smile.gif) I'll be heading over to the shop in a little while, need to ship out some 'sold' parts ... |
| OU8AVW |
Sep 28 2012, 01:09 PM
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
I scored another set of 2.0 Fuchs, they were cheap!
Then my $75 Piston set cam in. I unpacked them to discover that they are new KB 96mm pistons! Score! |
| JoeSharp |
Sep 28 2012, 03:22 PM
NARB, not a real bug. It's a '73 Superbeatle.
| euro911 |
Sep 28 2012, 07:17 PM
Took one of the neighborhood kids out for a little drive this afternoon (IMG:style_emoticons/default/rolleyes.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1245.photobucket.com-7300-1348881427.1.gif) (IMG:style_emoticons/default/laugh.gif) |
| championgt1 |
Sep 28 2012, 09:52 PM
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,682 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Washed it for the first time in a long time. Then I drove the piss out of it! (IMG:style_emoticons/default/beerchug.gif)
| hot_shoe914 |
Sep 29 2012, 11:35 PM
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Tracked down the problem of why my throttle was messed up and repaired it. Replaced the pedal cluster with a nice rebuilt one from Bruce Stone, had to weld a piece that was worn and wobbly. Pretty sure brake pedal was bent also. While we were in there, treated some minor surface rust under the cluster and coated the area with por-15. Everything works nicely now. (IMG:style_emoticons/default/aktion035.gif)
| JRust |
Sep 29 2012, 11:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
I picked up my new cable shift 901 tranny for my LS1 conversion (IMG:style_emoticons/default/biggrin.gif) . Thanks Mike (IMG:style_emoticons/default/piratenanner.gif)
| Phoenix-MN |
Sep 30 2012, 06:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Finished putting the engine together and re-attached the gearbox. It's ready to slip back into the car now (IMG:style_emoticons/default/piratenanner.gif)
Should havit running again just in time for the snow (IMG:style_emoticons/default/hissyfit.gif) |
| mittelmotor |
Sep 30 2012, 07:58 PM
Member ![]() ![]() Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Took some pics! Low light helps hide the flaws, like the semi-nasty front valance (will get LE replica at some point). I finally settled on a front ride height that's low enough to look cool and high enough to be usable. Not a single scrape on the under-car coolant hoses. Rear ride height gives decent clearance for oilpan, which extends slightly below engine beam.
I'm pleased with how the front grillework came out...not too noticeable between the bumperettes. Mesh is from a 914 engine cover, so it keeps it all consistent. Went through about 10 Dremel cut-off wheels paring it down. (Gotta change resolution on photos; using a different camera) Attached thumbnail(s) |
| euro911 |
Sep 30 2012, 10:59 PM
Finished putting the engine together and re-attached the gearbox. It's ready to slip back into the car now (IMG:style_emoticons/default/piratenanner.gif) Yeah, like getting the AC fixed in my Tacoma just in time for winter (IMG:style_emoticons/default/blink.gif) Should havit running again just in time for the snow (IMG:style_emoticons/default/hissyfit.gif) Checked out your build page. Nice project (IMG:style_emoticons/default/aktion035.gif) From the date on your video, looks like you already had it running earlier in the year. Why did you pull the drive train back out? Sounds nice and quiet. Is that a Boxter muffler? (IMG:style_emoticons/default/confused24.gif) Also, what is the blue device in the right drive flange? ... hall effect trigger for an ECU? By any chance, do you still have the cowl you cut the 911 dash from? I'm looking for a section to repair a rusted-out trunk seal tray in my '67 (IMG:style_emoticons/default/happy11.gif) |
| bulitt |
Oct 1 2012, 05:43 AM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
"Also, what is the blue device in the right drive flange? ... hall effect trigger for an ECU? "
Electronic Speedo |
| Phoenix-MN |
Oct 1 2012, 06:34 AM
[quote name='euro911' date='Sep 30 2012, 08:59 PM' post='1746807']
[quote name='Phoenix-MN' post='1746648' date='Sep 30 2012, 05:37 PM'] From the date on your video, looks like you already had it running earlier in the year. Why did you pull the drive train back out? Sounds nice and quiet. Is that a Boxter muffler? (IMG:style_emoticons/default/confused24.gif) Also, what is the blue device in the right drive flange? ... hall effect trigger for an ECU? By any chance, do you still have the cowl you cut the 911 dash from? I'm looking for a section to repair a rusted-out trunk seal tray in my '67 (IMG:style_emoticons/default/happy11.gif) [/quote] Yes, it was together and running for a couple of years. Harmonic balancer blew up and the replacement threw the engine balance off and needed to be re-done. Durring tear down I discovered some major F-Up's by the previous machine shop that had to be fixed (IMG:style_emoticons/default/mad.gif). Yup, a Boxster S muffler, it is quiet but does have a nice growel when you get on it. Trigger wheel for the electronic speedometer Sorry, all the 911 sheet metal is long gone. |
| bulitt |
Oct 1 2012, 10:49 AM
Thats one beautiful car! Eight yrs of work? I'll be lucky to be alive in eight yrs. (IMG:style_emoticons/default/lol-2.gif)
| Eddie914 |
Oct 1 2012, 11:43 AM
Unregistered |
Drove it!
500 highway miles and 9 hillclimb runs at Maryhill Loops Road. Push started it too many times (heat soaked starter)! Wiped up lots of oil ?!?! Now it's time to find the oil leak and replace the starter. |
| Porsche930dude |
Oct 2 2012, 04:56 PM
Member ![]() ![]() Group: Members Posts: 399 Joined: 25-November 11 From: NY Member No.: 13,819 Region Association: None |
stuck my front flars on. almost done (IMG:style_emoticons/default/happy11.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-13819-1349218608.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-13819-1349218609.2.jpg) |
| euro911 |
Oct 2 2012, 11:54 PM
Steel or glass, 'dude'? Looks good.
I need to do a few things to the 'BB' (in prep for the Halloween Run), but the daily driver needed some attention first. Changed out the front struts on the old Tacoma this evening (lower mount bushings were shot). Why did I wait so long (IMG:style_emoticons/default/confused24.gif) ... it handles like a new truck again (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/smile.gif) |
| Nürburg Nomad |
Oct 3 2012, 12:25 AM
914Rubber.com! ![]() ![]() Group: Members Posts: 296 Joined: 30-March 10 From: Buckeye State Member No.: 11,536 Region Association: Upper MidWest |
Took some pics! Low light helps hide the flaws, like the semi-nasty front valance (will get LE replica at some point). I finally settled on a front ride height that's low enough to look cool and high enough to be usable. Not a single scrape on the under-car coolant hoses. Rear ride height gives decent clearance for oilpan, which extends slightly below engine beam. I'm pleased with how the front grillework came out...not too noticeable between the bumperettes. Mesh is from a 914 engine cover, so it keeps it all consistent. Went through about 10 Dremel cut-off wheels paring it down. (Gotta change resolution on photos; using a different camera) Looks GREAT! Love those wheels and the stance under the factory fenders! (IMG:style_emoticons/default/drooley.gif) |
| 6freak |
Oct 3 2012, 03:13 PM
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
may have found a stable mate for her...we will see (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 28th November 2025 - 12:12 PM |
