| Root_Werks |
Oct 30 2026, 02:21 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,092 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Black looks so good on 914's.
| Shivers |
Oct 30 2026, 04:24 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,717 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| Maltese Falcon |
Oct 30 2026, 07:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
| Shivers |
Oct 31 2026, 02:21 AM
I like the round discs welded in place as well, the sheet metal firewall is approximately .20ga. thick; strength is your friend. Oh yeah, I feel better now about that choice. Just seemed like the way to do it. Thanks Marty (IMG:style_emoticons/default/smile.gif) |
| flyer86d |
Oct 31 2026, 01:44 PM
Member ![]() ![]() Group: Members Posts: 490 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
We’ve moved this summer, three houses away, so I finally got to install the new suspension in the 914-6. Last summer, I cleaned and painted the replacement which is 73 911S with big aluminum calipers and the rear is 914-6 all with delrin bushings.
The hard part is finding everything after moving. This car has been boxes since 1975 and moved 4 times. While most of the parts are in good shape, it’s a matter of finding, cleaning and remembering how it goes back together. Anyway, the suspension is installed, next to connect up the brake lines, install the sway bars and assemble the doors and glass. In comparison to a 356 or early 911, the 914 is a lot more fussy with more small parts and pieces. Charlie |
| euro911 |
Oct 31 2026, 03:14 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,951 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Black looks so good on 914's. I miss the old 'BB' at times - it was a fun car ![]() ![]() |
| euro911 |
Nov 1 2026, 07:26 AM
Old news (2021), but I just read about it on the 912bbs
Glad they caught the POS and his crew ... https://www.ktvu.com/news/suspect-arrested-...egal-chop-shops |
| 930cabman |
Nov 1 2026, 05:22 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,882 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Charlie is a glutton for sure
This car has been boxes since 1975 and moved 4 times. wow, good luck Charlie |
| BillC |
Nov 1 2026, 08:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 761 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
| L-Jet914 |
Nov 1 2026, 08:22 PM
Member ![]() ![]() Group: Members Posts: 437 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Installed a set of SpokeWorks tail light led boards and side marker bulbs on my 74 1.8 back in August. Finally got some time to post them here. I am very pleased with how bright they are at night. I am glad that people behind me can see me when I apply the brakes or turn on the turn signals. I am also glad that I am more visible when I happen to drive in the evening. Amazing product @Spoke . I recommend these to all Teeners for increased visibility and safety (IMG:style_emoticons/default/smile.gif)
Attached thumbnail(s) |
| sixnotfour |
Nov 2 2026, 12:04 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,425 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Willow went to home .. Utah Long drive,, No Problems.. (IMG:style_emoticons/default/driving.gif)
| Shivers |
Nov 3 2026, 03:17 PM
Fuel tank in.
| euro911 |
Nov 4 2026, 11:06 AM
Did you get a Carter fuel pump and mount it up front to keep it out away from the heat under the engine tin?
(IMG:style_emoticons/default/confused24.gif) |
| Shivers |
Nov 4 2026, 11:43 AM
Did you get a Carter fuel pump and mount it up front to keep it out away from the heat under the engine tin? (IMG:style_emoticons/default/confused24.gif) Next time. I had to use the Holley pump I had already. And it is built like Felix the Cat’s nemesis the Master Cylinder. |
| euro911 |
Nov 6 2026, 11:28 AM
The pump you have is probably fine. It was more about placing pump nearer the fuel tank for 2 reasons:
1. Getting the pump awwy from heat sources to combat vapor lock. 2. Pumps push better than pull. |
| mgp4591 |
Nov 6 2026, 01:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,071 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
[quote name='BillC' date='Nov 1 2026, 07:04 PM' post='3277233']
I took mine to The Gathering of the Faithful today. It's a local car show for air-cooled Porsches. That looks like a good turnout, Bill! Where in the area was this show? That's my old area as well, being born in Bethesda, growing up in PG county, and ending up in Frederick before finally moving to Utah. I still get back there every couple of years. |
| JmuRiz |
Nov 7 2026, 09:34 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,655 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
It was in Brookvile, just north of Olney. Good to see the turnout, I haven’t been motivated to attend since my bad 356 experience 9 years ago, but next year I need to get motivated again.
| slivel |
Nov 7 2026, 11:35 AM
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 556 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
| Shivers |
Nov 7 2026, 12:04 PM
| eric9144 |
Nov 9 2026, 03:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,805 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California
Finally got some crows foot tools and got at my gas tank leak.
Props to PMS for sending me parts *free* for the fix -- was a little intimidated by the repair but it turned out to be quite easy, maybe ~1hr all in once I had the tools to get the fittings off the bottom of the tank. This was my view through the hole under the steering rack (IMG:style_emoticons/default/dry.gif) Tank out, pretty easy, swapped out the old cork gasket, some of the screws were suprisingly "un" tight (IMG:style_emoticons/default/mad.gif) So far so good, no leaks, going to get under it again tonight to check to make sure things are dry still then I'll button it all back up and get it out for a LONG overdue dust off drive (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 15th November 2026 - 12:57 AM |
