884 Pages V « < 95 96 97 98 99 > »
euro911
post Oct 30 2012, 02:09 AM
Post #1921
Sold all the 914s and bought this '84 Wasserboxer Westy:
It's been nice knowing you all ... see ya over on Samba (IMG:style_emoticons/default/laugh.gif)
Actually, I treated some surface rust on the belly pan of the 'BB' last Friday and undercoated it today:
Tomorrow, I'll lower it down to the ground, start it up, and see if the new fat 'valve' cover gaskets I installed last week stopped the oil leak. If so ... hoping to take it on the Halloween Run (IMG:style_emoticons/default/driving.gif)
Also, will be stocking the shelves with parts I bought at the G&R (IMG:style_emoticons/default/smile.gif) ... as well as restocking all the stuff that didn't sell (IMG:style_emoticons/default/dry.gif)
oldschool
post Oct 30 2012, 11:19 AM
Post #1922
Got this worn out cluster....out(Ethan Kuhl) 73-914 kid was cool enough to take the time to do this for me... Attached Image
Porsche930dude
post Oct 30 2012, 05:48 PM
Post #1923
brought my engine up out of the basement and assembled it to the tranny in the garage. Another day or 2 and itll be in the car
gunny
post Oct 30 2012, 05:57 PM
Post #1924
Today I changed the oil. Completed hell hole repair. Tried to fix small leak at oil temp sensor. That's it for today
iamchappy
post Oct 30 2012, 08:17 PM
Post #1925
It all happens so fast!
Mines ready for Halloween ....
914itis
post Oct 30 2012, 08:46 PM
Post #1926
I did a lot since sandy kept me In The garage . I reupholstered my dash, took down my transmission to replace front and shift rod seals , tranni and dash are both back in.
ConeDodger
post Oct 30 2012, 08:58 PM
Post #1927
Apex killer!
Added some low RPM accelerator pump fuel, increased the accelerator pump sensitivity and added lots more high RPM fuel.
Ahhh... Programmable fuel injection. So easy! (IMG:style_emoticons/default/evilgrin.gif)
Took a vicious cool top off drive up Mt. Rose Hwy (IMG:style_emoticons/default/driving.gif)
Eric_Shea
post Oct 30 2012, 09:09 PM
Post #1928
PMB Performance
Un-hooked my rear sway bar... Ahhhhhhhhhhhhhhhhh...
Jesco Reient
post Oct 30 2012, 09:32 PM
Post #1929
Day 104 of the "Tune up"
Today I got to the part of the "Tune Up" where the crankcase gets torqued up and measured to see if it is still a player.
(IMG:http://www.914world.com/bbs2/uploads_offsite/carphotos3.cardomain.com-14690-1351654337.1.jpg)
Gint
post Oct 30 2012, 09:54 PM
Post #1930
Mike Ginter
I drove the $*!( outa mine today.
euro911
post Oct 31 2012, 12:21 PM
Post #1931
I didn't, so mine's still full of $*!( ... (IMG:style_emoticons/default/laugh.gif)
'BB' is still up on the lift, it didn't want to start last night (IMG:style_emoticons/default/dry.gif)
Put a charger on the battery, and since I haven't located a replacement passenger-side glass rocker panel yet, I removed the driver side, cleaned up both longs and sprayed under-coating on them. Guess I'll run without rocker panels for a while (IMG:style_emoticons/default/confused24.gif)
Under-coating should be dry enough to test drive it sometime today (IMG:style_emoticons/default/driving.gif)
Also, cleaned up a little oil residue in the engine bay and checked the wire to the oil temp gauge. Gauge checked out OK. It hasn't registered any movement since we installed the new drive train, so looks like the taco sensor might be bad. Fresh Brad Penn 20/50 with only 700 miles in there now ... so I'll wait until it's time to change the oil to replace the sensor.
Porsche930dude
post Oct 31 2012, 05:09 PM
Post #1932
Punched a few holes. Gotta love that greenlee die set! Had to make my own flange die to go big enough but that was pretty easy
(IMG:http://www.914world.com/bbs2/uploads_offsite/i721.photobucket.com-13819-1351724993.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i721.photobucket.com-13819-1351724993.2.jpg)
euro911
post Oct 31 2012, 07:47 PM
Post #1933
Is it the hydraulic pump type? Like cutting butter with a hot knife.
Porsche930dude
post Oct 31 2012, 08:32 PM
Post #1934
yep it cuts pretty thick stuff too. I think i paid like $15. for it at a garage sale! I had my 911 packed with stuff from that sale
(IMG:http://www.914world.com/bbs2/uploads_offsite/i721.photobucket.com-13819-1351737164.1.jpg)
oldschool
post Oct 31 2012, 09:39 PM
Post #1935
Attached Image ..time to start the clean up
euro911
post Nov 1 2012, 05:27 AM
Post #1936
More work on the 'BB' today.
Finally bolted my 'temporary' EMPI oil breather to the firewall (it was Ty-Wrapped in for the RT-66 Run and flopping around, spilling oil everywhere) (IMG:style_emoticons/default/dry.gif) ... and re-routed the hoses.
Readjusted the front suspension height.
I found the problem with my oil temp gauge issue. The wire was disconnected from the spade terminal at the sensor, but was still crimped on to the jacket (IMG:style_emoticons/default/blink.gif) ... installed a new terminal (IMG:style_emoticons/default/smile.gif)
With the battery all charged up, started it up and checked for oil leaks. NONE (IMG:style_emoticons/default/mueba.gif)
914Rubber.com valve cover gaskets are 'BB' approved (IMG:style_emoticons/default/laugh.gif) ... Thanks Mark (IMG:style_emoticons/default/beerchug.gif)
Around midnight, hopped on the Harbor Fwy and drove several miles south, then back to the shop to check it out. Still needs some carb fine tuning (IMG:style_emoticons/default/dry.gif)
Had another clogged idle jet, cylinder #3 this time. I really need to find out where this crud is coming from (IMG:style_emoticons/default/mad.gif)
The tank is clean, there's a new Carter pump & filter under the tank, new SS fuel lines, all new hoses (the expensive stuff) and there's another filter in the engine bay (IMG:style_emoticons/default/confused24.gif)
Put the car back on the lift, swept the shop floor and came home. It's 4:30am - good night (IMG:style_emoticons/default/yellowsleep[1].gif)
Porsche930dude
post Nov 1 2012, 04:35 PM
Post #1937
got my pedal cluster and master cyl intalled and more of the lines done. After dropping a rear caliper on my big toe with no shoes on I discovered a chucky cheese token presses in perfectly in place of the big plug
oldschool
post Nov 1 2012, 04:37 PM
Post #1938
Clean up time..next all new rubber seals....
euro911
post Nov 1 2012, 07:25 PM
Post #1939
QUOTE(Porsche930dude @ Nov 1 2012, 03:35 PM) *
... After dropping a rear caliper on my big toe with no shoes on I discovered a chucky cheese token presses in perfectly in place of the big plug
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Jesco Reient
post Nov 1 2012, 11:02 PM
Post #1940
QUOTE(oldschool @ Nov 1 2012, 03:37 PM) *
(IMG:http://www.914world.com/bbs2/uploads/post-9705-1351809438_thumb.jpg)
Oldschool, Nice...........Clean up and New seals got me to here. If you look at things too closely you may end up here also. it is a slippery slope. What year/size is that motor?
185 User(s) are reading this topic (185 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th November 2025 - 10:54 AM
