| '73-914kid |
Oct 8 2013, 09:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Had to run out and grab some chemistry supplies, so I took the top off and cruised around the Walnut/Diamond Bar area.. stopped for a bite to eat, and drove into the sunset back to school. Not a bad evening at all (IMG:style_emoticons/default/biggrin.gif)
| boxsterfan |
Oct 8 2013, 10:47 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Began the prep of a "new to me" 1974 2.0L for regular driving. Changed oil and filter. Verified the cooling flaps open when warmed up. Still trying to figure out of it is running hot or not.
Next up: 1. Take some pics 2. Install new sending unit and vdo gauge 3. Change tranny oil 4. Install new vacuum lines 5. Figure out the rough idle after engine warms up. Hoping to get it sorted this weekend otherwise I might as well (IMG:style_emoticons/default/sheeplove.gif) |
| Mike Bellis |
Oct 8 2013, 10:58 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I opened the garage and looked at mine... (IMG:style_emoticons/default/sad.gif)
| shoguneagle |
Oct 9 2013, 01:01 AM
shoguneagle ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
I got some critical parts taken in the theft; car is starting to become active again and not a "boat anchor". Got a DME and front bumper which will allow me to get it running and licensing in Oregon; more parts coming thanks to the 914world members. Will soon have enough to put it together and start upgrading for the objective of final painting.
| JoeSharp |
Oct 9 2013, 02:02 AM
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Moved it back about 10' by hand. Well at least I touched it.
| euro911 |
Oct 9 2013, 02:18 AM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
I had auto shop class tonight, so I drove the old 'BB' again. Finally got access to a lift and found a loose cone screw at the shift console. Took the cup off, lubed it and reinstalled it, tightening the cone screw as tight as I dared to (didn't have any lock-tite handy, so I hope it holds) (IMG:style_emoticons/default/sad.gif)
Also checked the front cone screw ... I can report back that all was OK there. Added a little grease to the shaft there too. While still on the lift, also adjusted the clutch pull and leveled the front suspension (was listing on the driver's side a tad, even without my fat ass in the seat). Cleaned out cylinder # 2's idle jet AGAIN. Why is this one jet always clogging? (IMG:style_emoticons/default/WTF.gif) Put fresh air in all 4 tires before leaving and it ran a lot better on the way home. It sure is nice to have 1st. and reverse gears at my finger tips again (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/smile.gif) |
| euro911 |
Oct 9 2013, 02:25 AM
Finally got sick of the noisy Monza exhaust. Ordered new gaskets and nuts and dropped off the original muffler at Finishline Coating for ceramic thermal barrier coating in a raw steel finish. Are they dipping it (coating inside and out)? I'd like to do this to my (IMG:style_emoticons/default/mueba.gif) muffler too. How much are they charging you? |
| bulitt |
Oct 9 2013, 08:52 AM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Well, I lost my nuts!
Seriously, no matter how organized I try to be, bagging and tagging, and boxing I still manage to lose nuts, bolts, brake stuff. (IMG:style_emoticons/default/headbang.gif) I learned today, a good place to find metal objects is on the speaker magnet. (IMG:style_emoticons/default/biggrin.gif) Installing my brakes lines. |
| JawjaPorsche |
Oct 9 2013, 03:39 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Went to town and fill the tank up with 100% gas before making the trip to Okteenerfest. Should make it back before needing more fuel. Awesome fall weather! Mid-70's, ZERO chance of rain! Okay, I have jinx us!
| Mblizzard |
Oct 9 2013, 04:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Went to town and fill the tank up with 100% gas before making the trip to Okteenerfest. Should make it back before needing more fuel. Awesome fall weather! Mid-70's, ZERO chance of rain! Okay, I have jinx us! Will be doing that tonight and heading to Okteenerfest tomorrow. I hope to drive hard enough to need gas before I come back. If it rains, you have to wipe down everyone's car now that you said it! |
| Mike Bellis |
Oct 12 2013, 07:28 PM
| wndsnd |
Oct 12 2013, 08:13 PM
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Finally got my engine in! (IMG:style_emoticons/default/biggrin.gif)
All lights look good. Starter turns over. Tomorrow I am going to fire up that dANNY special (IMG:style_emoticons/default/blink.gif) |
| euro911 |
Oct 12 2013, 09:35 PM
The 'BB' has become my 'DD' since the shifting problem has been mitigated (IMG:style_emoticons/default/mueba.gif)
| KaptKaos |
Oct 14 2013, 12:09 AM
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Drove her all over today. Was a lot of fun too.
| 993inNC |
Oct 14 2013, 05:08 PM
Member ![]() ![]() Group: Members Posts: 194 Joined: 14-August 09 From: at the beach Member No.: 10,676 Region Association: South East States |
Put my dash back together last night. Working a little bit at a time (IMG:style_emoticons/default/smile.gif)
Attached thumbnail(s) |
| bulitt |
Oct 14 2013, 05:17 PM
Looks great Chris!!!
Put new Aluminum fuel line in today! |
| JmuRiz |
Oct 14 2013, 07:21 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,626 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Put my dash back together last night. Working a little bit at a time (IMG:style_emoticons/default/smile.gif) Who did your leather/stitched dash? Looks good! Btw today I tallied up the price of parts on my car...yikes. |
| Pat Garvey |
Oct 14 2013, 07:38 PM
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
Finally bought 5 tires (Kumho's), mounted them on the chromies. Will be cleaning suspension pieces as I install. Should be back on the ground by Friday, for the first time in over 6 years!
Fuel tank and injection parts will need to be replaced but have everything to do so (all new, except for the replacement tank). Getting ready to order Tangerine lines and will have to farm out most everything since I'm getting older. |
| poorsche914 |
Oct 14 2013, 09:13 PM
9fourteen ![]() ![]() ![]() ![]() Group: Members Posts: 3,151 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Found this in a care package of 914 stuff given to me by a fellow PCA member who recently moved and was clearing out all his old Porsche junk.
![]() (IMG:style_emoticons/default/driving.gif) |
| infraredcalvin |
Oct 14 2013, 10:12 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,743 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
Lo-Fi Version | Time is now: 28th April 2026 - 08:02 PM |
