| ONTHEGRIND |
Jan 2 2014, 11:16 PM
Member ![]() ![]() Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None |
Beat up the cars today chasing down other Porsches on the annual New Years Day drive. Porsche of Livermore catered breakfast for 150 drivers and guest. Huge turn out and great road conditions. Drove the crap out of the cars. Kathy was able to keep up with all the six cylinder cars by staying off the brakes and driving thru the corners. Drivers meeting. Cars on top of Mt. Hamilton. A well deserved lunch break. I seen these two driving down 87 I gave a thumbs up I was on the ducati... |
| Mike Bellis |
Jan 3 2014, 12:18 AM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Nothing to the 914. (IMG:style_emoticons/default/sad.gif)
I picked up a 2000 Jetta for $300 with a major ATF leak. I searched the web and read all the horror stories about pump seals and torque converters... Turns out the pan was loose and fluid was just pouring over the gasket. 15 minute fix! (IMG:style_emoticons/default/piratenanner.gif) Bought it from a friend when a shop gave them an estimate of $1300 to fix it. My friends took my money and bought a new Jetta. Win, win... |
| Michael N |
Jan 3 2014, 10:19 AM
Certifiable ![]() ![]() ![]() Group: Members Posts: 1,432 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
Beat up the cars today chasing down other Porsches on the annual New Years Day drive. Porsche of Livermore catered breakfast for 150 drivers and guest. Huge turn out and great road conditions. Drove the crap out of the cars. Kathy was able to keep up with all the six cylinder cars by staying off the brakes and driving thru the corners. I seen these two driving down 87 I gave a thumbs up I was on the ducati... You have an awesome motorcycle. |
| chads74 |
Jan 3 2014, 06:10 PM
Member ![]() ![]() Group: Members Posts: 386 Joined: 13-March 12 From: Tampa, FL Member No.: 14,252 Region Association: South East States |
| CG-914 |
Jan 3 2014, 07:53 PM
Member ![]() ![]() Group: Members Posts: 327 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Replaced my broken brake res. cap, turns out the new one is not as deep as the original one. Dangerous to tighten without creaking it easy (again).
And replaced my passenger window crank with an original one after 2 aftermarket ones broke... (IMG:style_emoticons/default/dry.gif) |
| chads74 |
Jan 3 2014, 10:44 PM
| Michael N |
Jan 3 2014, 10:58 PM
Looks good. Hey that kids bike and scooter are too close to your 914. Accident waiting to happen. (IMG:style_emoticons/default/biggrin.gif)
| carr914 |
Jan 4 2014, 02:09 PM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 132,426 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
It was Porsche Saturday as I met up with bcheney at my Engine Builders New Shop, so my guy could evaluate Brian's 911 Engine problem
![]() then over to St Pete where my friend John got his Car from Camp914 ![]() |
| DRPHIL914 |
Jan 4 2014, 08:53 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,922 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
Got my newly refurbished trailing arms mounted today! Thanks to Eric and Pmb for putting the new 5 lug hubs on and the new bearing pressed in as well. Next to put on the new calipers and brake Lines from PMB.
Attached thumbnail(s) |
| JStroud |
Jan 4 2014, 11:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Got my newly refurbished trailing arms mounted today! Thanks to Eric and Pmb for putting the new 5 lug hubs on and the new bearing pressed in as well. Next to put on the new calipers and brake Lines from PMB. Very nice, Eric does nice work! (IMG:style_emoticons/default/beerchug.gif) Looking good Jeff |
| campbellcj |
Jan 6 2014, 12:24 AM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,706 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
Today was the first day in a very long time that I worked on my car myself...
I changed the clutch cable, which is an un-fun job on any 914 but even worse with a full rollcage. Supposedly Terry Cables don't break... (IMG:style_emoticons/default/idea.gif) (Granted, this cable may have been 10 years old. I went back to stock this time.) I also installed a Triad muffler I got a while back, in place of megaphones, so I can test drive a bit on the street before heading to the track in a few weeks. Attached image(s)
| '73-914kid |
Jan 6 2014, 12:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Terry cables do break, I've broken one in my car, and one broke in a buddies. They chafe inside the tunnel because they run unsheathed through a metal tube and under high tension. Mine didn't last long, and I'm going on 3 years of daily driver abuse with my stock GEMO cable..
| carr914 |
Jan 6 2014, 06:45 AM
I test fitted the Revolutions
| euro911 |
Jan 6 2014, 11:12 AM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Paint the centers of those rotors (IMG:style_emoticons/default/slap.gif)
| chads74 |
Jan 6 2014, 11:15 AM
| carr914 |
Jan 6 2014, 06:04 PM
They fit OK with the 7s both on one side - the 8s don't fit
| carr914 |
Jan 6 2014, 06:35 PM
| Dasnowman |
Jan 6 2014, 11:34 PM
You miss 100% of shots you don't take! ![]() ![]() Group: Members Posts: 265 Joined: 24-May 12 From: Tricities, B.C./ Lake Whatcom Member No.: 14,477 Region Association: Canada |
Love your Car hopefully mine will look like that one day! |
| euro911 |
Jan 7 2014, 12:16 AM
What's the story on that blue one?
| chads74 |
Jan 7 2014, 11:13 AM
What's the story on that blue one? I was wondering if you had the wide ones on, looked like there was plenty of room, but that explains it. Do tell about the blue one |
Lo-Fi Version | Time is now: 28th April 2026 - 08:30 AM |
