| BeatNavy |
Feb 20 2016, 05:23 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,967 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Got the floor pan off my "project" car. Wow, that was FUN. Got to see what few on this planet have witnessed: the inside of the 914 center tunnel.
![]() ![]() And, yes, here is another reminder that by restoring this 914 I have denied a family of rodents a good home (these liked peanuts, apparently): ![]() Attached image(s)
| Cuda911 |
Feb 20 2016, 08:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Topped off the oil, aired up the tires, washed and waxed it, and drove.
| BeatNavy |
Feb 20 2016, 08:37 PM
Topped off the oil, aired up the tires, washed and waxed it, and drove. Yeah. Whatever. I'm sure I had much, much more fun drilling out a billion spot welds removing my floor plan than you did driving along the beach. On a beautiful southern California day. With hot chicks hanging out... (IMG:style_emoticons/default/blink.gif) |
| Cuda911 |
Feb 20 2016, 08:40 PM
But at least you got free peanuts.
| BeatNavy |
Feb 20 2016, 08:54 PM
But at least you got free peanuts. Yeah, that was pretty sweet (IMG:style_emoticons/default/biggrin.gif) |
| SKL1 |
Feb 20 2016, 09:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,827 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest
Always enjoy Cuda's scenery pictures from sunny SoCal... we've got lots of sun and cacti around here (and I don't miss the IA snow at all this time of year!)
My son and I taking a leisurely cruise around north Scottsdale... ![]() |
| jcav |
Feb 20 2016, 11:20 PM
Newbie ![]() Group: Members Posts: 35 Joined: 4-April 15 From: albuquerque/ames Member No.: 18,595 Region Association: None |
| Bossman |
Feb 21 2016, 09:14 AM
Member ![]() ![]() Group: Members Posts: 67 Joined: 6-October 14 From: Red Bluff CA Member No.: 17,985 Region Association: Northern California |
| bulitt |
Feb 21 2016, 09:41 AM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Topped off the oil, aired up the tires, washed and waxed it, and drove. Yeah. Whatever. I'm sure I had much, much more fun drilling out a billion spot welds removing my floor plan than you did driving along the beach. On a beautiful southern California day. With hot chicks hanging out... (IMG:style_emoticons/default/blink.gif) Would have been more fun doing it underneath the car, with no rotisserie, with rust all over your face! (IMG:style_emoticons/default/biggrin.gif) |
| bulitt |
Feb 21 2016, 09:51 AM
Finished preserving my original floor pans (de-tar, de-seam sealer, wire wheel everything, ospho, 2 coats rust bullet). I may brush on some new seam sealer this week. How do you like working with Rust Bullet? Are you going to top coat over it? When I restored my LoCort I used RB with good results but the purists frowned on it.....I just said it's my car and I'll do what I want with it and that was the end of that. (IMG:style_emoticons/default/biggrin.gif) So far, so good. I haven't had great luck with POR-15 (and neither have many others), so I figured I'd try RB. The pros recommend epoxy primer, but I'm not really set up to spray. My floor pans were in really good shape to begin with. Arizona/California car and I don't intend on ever taking this out in winter or rain here. Brushing RB on was super easy. I applied 2 coats. No topcoat. I'll be putting dynamat-type stuff over most of the floor pans to replace the tar. As I understand it, the Ospho is what does all the work with stopping rust. The RB just seals the metal and prevents moisture from getting in. Let's see how it holds up. I simply brushed the Epoxy Primer on my floors. Came out great. |
| cary |
Feb 21 2016, 10:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
| BeatNavy |
Feb 21 2016, 11:22 AM
Thanks, Cary. I actually had really good results this time with the Eastwood cutter (EW Cutter). I also got, of course, the three pack bit replacement.
Tried Harbor Freight's version a while back (IMG:style_emoticons/default/barf.gif) and spent a fair amount of money on Blair, but I found the bits broke too quickly. Course I was mainly using the Blair on a suspension console which is a PITA, but I like that Eastwood cutter. Seemed to last the longest. |
| Steve |
Feb 21 2016, 11:33 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,107 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
| cary |
Feb 21 2016, 11:41 AM
Thanks, Cary. I actually had really good results this time with the Eastwood cutter (EW Cutter). I also got, of course, the three pack bit replacement. Tried Harbor Freight's version a while back (IMG:style_emoticons/default/barf.gif) and spent a fair amount of money on Blair, but I found the bits broke too quickly. Course I was mainly using the Blair on a suspension console which is a PITA, but I like that Eastwood cutter. Seemed to last the longest. I'm finding the same thing on the Blair/Hougen/Rotacut. One slight angle deviation, or catch a another spot weld. Snap ....... On the Eastwood. Did you buy the Rotacut type or the drill bit type? |
| BeatNavy |
Feb 21 2016, 12:04 PM
Thanks, Cary. I actually had really good results this time with the Eastwood cutter (EW Cutter). I also got, of course, the three pack bit replacement. Tried Harbor Freight's version a while back (IMG:style_emoticons/default/barf.gif) and spent a fair amount of money on Blair, but I found the bits broke too quickly. Course I was mainly using the Blair on a suspension console which is a PITA, but I like that Eastwood cutter. Seemed to last the longest. I'm finding the same thing on the Blair/Hougen/Rotacut. One slight angle deviation, or catch a another spot weld. Snap ....... On the Eastwood. Did you buy the Rotacut type or the drill bit type? Sorry, this is the one I got: EW Skip Proof Cutter (drill bit type). Now I have to figure out what to put on the brand new floor pan, especially in the tunnel, to keep it from ending up like the old one (below). I've got Rust Encapsulator. Thought maybe Rust Bullet, or should I get an aerosol enamel primer? Any suggestions for brand new metal? ![]() |
| jim_hoyland |
Feb 21 2016, 01:30 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,151 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Sold my Saphire XXIII and filled the hole with a cubby out of my Boxster. Almost a perfect fit; the liner in the cobby's bottom is a non-slip rubber: perfect for storing the iPhone
| cary |
Feb 21 2016, 03:54 PM
Quote : from BeatNavy
Sorry, this is the one I got: EW Skip Proof Cutter (drill bit type). Now I have to figure out what to put on the brand new floor pan, especially in the tunnel, to keep it from ending up like the old one (below). I've got Rust Encapsulator. Thought maybe Rust Bullet, or should I get an aerosol enamel primer? Any suggestions for brand new metal? ![]() I'm using Eastwood Heavy Duty Anti-Rust on most areas that are enclosed. I am using Rustoleum in a couple others. http://www.eastwood.com/ew-heavy-duty-anti...-qts-black.html I'm going to order a 1/4" and a 3/8" version of this spot weld cutter. If they work out I'll order another pair. Then one pair can be sent in for sharpening while using the other. http://www.autobodytoolmart.com/14-cobalt-...er-p-12254.aspx |
| RickS |
Feb 21 2016, 06:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Installed Hawk "ceramic" performance pads on the 911S front calipers. Hopefully a it will stop a bit quicker and take care of the ridiculous squeal from the old pads.
It nice when people check out the car for the car, but not when the what brings their attention are shrieking brakes. |
| Larmo63 |
Feb 21 2016, 06:30 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I installed the Tangerine firewall bushing, the coupler bushings, and the rear cup, and a bronze rear bushing.
The shifting is stiff, but much clearer. It took a bit of driving to get it just right, so I had to drive it. The temps here are in the high 70's. Bummer. |
| forrestkhaag |
Feb 21 2016, 07:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
After a run up the coast to TJz, I worked on lowering the profile on my GT cap from a standing proud position above the hood to a hood slope profile position..... keep in mind, the tank doesn't move (down) and the filler neck doesn't move down easily either.
So it was out with the cutoff wheels, goggles, and earmuffs......... and first torch off the cap-receiver portion of the GT cap set that was welded to the new filler neck tube, then lop off what is an estimate of what is needed to be removed from the filler neck.... but not too much... It is another work in progress Attached thumbnail(s) |
Lo-Fi Version | Time is now: 27th October 2026 - 09:19 AM |
