| dangrouche |
Mar 6 2016, 09:52 PM
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
| Mr.Nobody |
Mar 6 2016, 11:25 PM
Member ![]() ![]() Group: Members Posts: 133 Joined: 24-March 15 From: San Diego, Ca Member No.: 18,557 Region Association: Southern California
Digging the carbon fiber on the strap. Nice touch.
Bought some stuff at the swap meet today. Rear sway bar, Weber manifolds for future use, an intake boot for current use, and some other trinkets. |
| gandalf_025 |
Mar 7 2016, 07:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,535 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
Finally was warm enough out in the garage yesterday to mount my new stainless bumper and "914" Rubber Top. The fog light grills I bought from the Dealership in the 70's and although dirty from storage, are new. Now have to wait for warmer days to mount the new dash. What's your opinion on the fit & finish of the stainless steel front bumper? Finish is great.... Rear bumper went on easy.... The Front, not as easy.. I had to elongate some of the mounting holes on top of the bumper to fit the rubber top on . The holes they drilled for mounting the driving light grills were off on the drivers side and had to be worked a little as well. Took some work to mount it right... |
| 1stworks |
Mar 8 2016, 09:29 AM
Member ![]() ![]() Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None |
Photo shoot.
European beauty American Muscle... (IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1457450971.1.jpg) |
| DRPHIL914 |
Mar 8 2016, 09:59 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
drove to work today - since re-crimping the connectors of the d-jet injector harness grounds and strapping the harness so that it will be less likely to move or pull loose, its running really good, no miss, no mess, no fuss. Well, now I need to look at why my idle is so rich but the running A/F is perfect part load and full load. and adjusting the ECU has no effect, so I guess the TPS is not set, I remember Rich saying that if the TPS is not set right then the idle adjustment on the ecu will not adjust - but I did put it in exactly the position that the picture he set says to, so any ideas?? - also noticed a bit of a front vibration at the wheel at 65mph on way to work, balance perhaps? I wonder if I lost weight off one of the wheels, they were inner weights- I didn't want to have any on outside of the new refurbished Fuchs I have on. Tires are 1 year old Bridgestone Potenza. Hm- always something... |
| Hank914 |
Mar 8 2016, 10:31 AM
Member ![]() ![]() Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
With all the rain, I need to wash it. Even with the covered parking. (IMG:style_emoticons/default/driving.gif) |
| BeatNavy |
Mar 8 2016, 12:21 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,967 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Well, now I need to look at why my idle is so rich but the running A/F is perfect part load and full load. and adjusting the ECU has no effect, so I guess the TPS is not set, I remember Rich saying that if the TPS is not set right then the idle adjustment on the ecu will not adjust - but I did put it in exactly the position that the picture he set says to, so any ideas?? - I believe there still is a relationship between MPS tuning and idle. The TPS does not 100% determine idle mixture. When the TPS is in the idle "position" that knob can be used to influence the idle mixture, but it is essentially adding or detracting from your "base" idle mixture determined by, among other things, the MPS. At least that's how I understand it. I think this may help: http://www.thesamba.com/vw/forum/archive/i...t-540502--.html |
| DRPHIL914 |
Mar 8 2016, 02:14 PM
Well, now I need to look at why my idle is so rich but the running A/F is perfect part load and full load. and adjusting the ECU has no effect, so I guess the TPS is not set, I remember Rich saying that if the TPS is not set right then the idle adjustment on the ecu will not adjust - but I did put it in exactly the position that the picture he set says to, so any ideas?? - I believe there still is a relationship between MPS tuning and idle. The TPS does not 100% determine idle mixture. When the TPS is in the idle "position" that knob can be used to influence the idle mixture, but it is essentially adding or detracting from your "base" idle mixture determined by, among other things, the MPS. At least that's how I understand it. I think this may help: http://www.thesamba.com/vw/forum/archive/i...t-540502--.html I will take a look at that. right now, after the last time I did a tweek to the MPS I brought my highway cruise and full load acceleration numbers into range, but before that were way lean,both the A/F on cruising was close to 15 and car ran hotter too, and now in the 12.8-13.7 range but my idle sits at 9.8 cold upon start up and still below 12, like 11-11.5 when warmed up. that seems a bit low to me but maybe that's o.k.? |
| BeatNavy |
Mar 8 2016, 02:35 PM
Well, now I need to look at why my idle is so rich but the running A/F is perfect part load and full load. and adjusting the ECU has no effect, so I guess the TPS is not set, I remember Rich saying that if the TPS is not set right then the idle adjustment on the ecu will not adjust - but I did put it in exactly the position that the picture he set says to, so any ideas?? - I believe there still is a relationship between MPS tuning and idle. The TPS does not 100% determine idle mixture. When the TPS is in the idle "position" that knob can be used to influence the idle mixture, but it is essentially adding or detracting from your "base" idle mixture determined by, among other things, the MPS. At least that's how I understand it. I think this may help: http://www.thesamba.com/vw/forum/archive/i...t-540502--.html I will take a look at that. right now, after the last time I did a tweek to the MPS I brought my highway cruise and full load acceleration numbers into range, but before that were way lean,both the A/F on cruising was close to 15 and car ran hotter too, and now in the 12.8-13.7 range but my idle sits at 9.8 cold upon start up and still below 12, like 11-11.5 when warmed up. that seems a bit low to me but maybe that's o.k.? Mine were in the 11 to 11.5 range at idle a few months ago, and I tweaked the MPS. Now more like 13 when warm, which I think is closer to where you want to be. If it goes too lean you get the surge action. I'd say to check your fuel pressure and TS1 sensor, but those would change mixture at all loads. Otherwise, once you get that LCR meter (you did order one, right?) you can do more experimentation with the inner screw and outer screw to bring idle down without compromising part load numbers. |
| DRPHIL914 |
Mar 8 2016, 02:49 PM
ok. so I just spent about 30 minutes scanning over this and it seems my idle number is pretty good. am I correct that larger number is more lean?
also looks like I may need to still do a bit of adjustment but for he 2 that I rebuild but car will not run (did not bench set them) I have a lot of adjusting to do, the car will not run they are so far off it wont start with one and the other if cold it runs but after a few minutes will not( I assume its way rich right now ) so I think this is well explained and gives a better understanding of how and why to tune theMPS so that it runs better across the whole spectrum. I still have high oil temps so I wonder if I will see that improve if I can get this tuning figured out. - thanks for the link!\ |
| 914Sixer |
Mar 8 2016, 06:42 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,600 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Phil,
Do you have the correct gauge and sender combination? Mixed match can lead to incorrect readings. Also is the wire from the sender to plug under battery in good shape? You could have a high resistance short in the wire? Try running a new temporary jumper wire and see if that changes oil temp. |
| kid914 |
Mar 8 2016, 08:09 PM
ALWAYS lead...NEVER follow!!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,543 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
When everything in the garage is fighting you all day, just scream out an expletive, quit, and move on to a crafty project that is hard to mess up...hahaha nice. (IMG:style_emoticons/default/beerchug.gif) |
| jcav |
Mar 10 2016, 12:09 AM
Newbie ![]() Group: Members Posts: 35 Joined: 4-April 15 From: albuquerque/ames Member No.: 18,595 Region Association: None |
I got the porsche running and the electrics and clutch figured out.
Now the gas pedal is sticking now in the open throttle position and the brake pedal is kind of sticky, not sure what to do. |
| BeatNavy |
Mar 10 2016, 07:01 AM
Drove it to work this morning, top off (IMG:style_emoticons/default/driving.gif)
Winter appears to be giving up without much of a fight this year here on the East Coast (I know, famous last words). I drove it as much as possible to work this winter, and it did fine. But the last two days, with nice weather and the top off...it's just a totally different car, and much more enjoyable experience! |
| A&P Mech |
Mar 10 2016, 07:25 AM
Member ![]() ![]() Group: Members Posts: 401 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
| Cracker |
Mar 10 2016, 07:46 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States
Out with the old and in with the new, eventually. Back at it today prepping the old engine for shipment to Cali...
Tony ![]() ![]() |
| 1stworks |
Mar 10 2016, 08:41 AM
| ndfrigi |
Mar 10 2016, 10:24 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,993 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
I got the porsche running and the electrics and clutch figured out. Now the gas pedal is sticking now in the open throttle position and the brake pedal is kind of sticky, not sure what to do. Probably the accelerator cable and clutch twisted with each other just below or after the shifter (clutch and accelerator tube on the same left side of the tunnel). Open the access hole on the right side of pedal and take a picture of the tunnel facing the rear to see the cables. |
| rangrbob |
Mar 10 2016, 10:33 PM
Member ![]() ![]() Group: Members Posts: 175 Joined: 11-October 12 From: Loveland, CO Member No.: 15,027 Region Association: Rocky Mountains |
My car seemed lonely.
![]() So, I brought home a garage mate for my 71. It's also a 71 (IMG:style_emoticons/default/smile.gif) I plan on getting the correct mirrors, Fuchs, and few other items it needs to bring it back to stock. ![]() ![]() |
| euro911 |
Mar 10 2016, 11:28 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,945 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
I sold my '67 912-6 (roller) this evening (IMG:style_emoticons/default/smile.gif) / (IMG:style_emoticons/default/sad.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-7300-1457674088.1.jpg) |
Lo-Fi Version | Time is now: 27th October 2026 - 08:56 AM |
