Rough Idle, One side hot, one side not |
Rhodes71/914 |
Aug 20 2004, 08:37 AM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Still trying to see if I can get my ebay purchase to run before I pull the engine.
Worked through some other issues with the help of members here, but here is what is happening now. Before I forget '71 1.7 D-Jet. Engine will start and idle but the idle is pretty rough. I can throttle up and get into the higher RPMs and it will idle without dieing (barely). Cylinders 3 & 4 and the intakes are pretty warm after running for a couple of minutes Cylinders 1 & 2 and those intakes show no heat at all. Help! |
Lo-Fi Version | Time is now: 28th May 2024 - 10:51 AM |
