Results from changing my tranny oil to SWEPCO 201, Comments on transmission oil. |
steuspeed |
Dec 18 2011, 07:20 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
So I have had my car about 6 months now. It has 105k on the clock. No record of when the last time the transmission oil was changed. First and second gear syncros are toast, but if I am real careful I can get it to slip in without grinding. Got to put it in first just before you come to a stop. I just changed the oil (Brad Penn) and thought it would be a good time to try some SWEPCO 201 in the transmission. The oil that drained out looked pretty good. Still had an amber color to it but a little on the low side. So now with the SWEPCO 3rd has a real notchy feel to it. second will zip on the teeth as I come down from third with my usual methods. First is even more finicky than before. Outside Temp is 35-45 degree range right now. Will this get better over time? Seems like I went backwards. (IMG:style_emoticons/default/sad.gif) Any comments welcome.
steuspeed |
Dec 18 2011, 10:39 PM
I'm replying on the wrong thread. I thought mine got hijacked. Anyway Dr. Evil. So I should be running this Red Line non synthetic GL5 gear oil 75W-90? Sounds like the stuff I need. Or maybe just run good old Valvoline like underthetire says.
http://www.redlineoil.com/product.aspx?pid=47&pcid=7 |
Dr Evil |
Dec 19 2011, 05:47 AM
Send me your transmission! Group: Members Posts: 22,999 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
So I should be running this Red Line non synthetic GL5 gear oil 75W-90? Sounds like the stuff I need. http://www.redlineoil.com/product.aspx?pid=47&pcid=7 I never said that. Regular dino oil was fine for the first 30 years. There is no magic lube without sacrifice/risk as I outline in my notes. |
Lo-Fi Version | Time is now: 18th May 2024 - 09:38 AM |
