Results from changing my tranny oil to SWEPCO 201, Comments on transmission oil. |
steuspeed |
Dec 18 2011, 07:20 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
So I have had my car about 6 months now. It has 105k on the clock. No record of when the last time the transmission oil was changed. First and second gear syncros are toast, but if I am real careful I can get it to slip in without grinding. Got to put it in first just before you come to a stop. I just changed the oil (Brad Penn) and thought it would be a good time to try some SWEPCO 201 in the transmission. The oil that drained out looked pretty good. Still had an amber color to it but a little on the low side. So now with the SWEPCO 3rd has a real notchy feel to it. second will zip on the teeth as I come down from third with my usual methods. First is even more finicky than before. Outside Temp is 35-45 degree range right now. Will this get better over time? Seems like I went backwards. (IMG:style_emoticons/default/sad.gif) Any comments welcome.
Mark Henry |
Dec 19 2011, 07:34 AM
About the only thing swepco has a bright blue colour and you can immediately tell if you have a trans leak.
I do think they have an acceptable engine oil for our older cars, still spendy for a dino oil. They have a excellent water resistant grease that can be used for everything, including CV's. I like the fuel injector cleaner, but mostly for doing a whole shot as it really cleans the carbon out of the engine, but doing this is a major freaking smoke bomb. |
Lo-Fi Version | Time is now: 24th May 2024 - 08:03 PM |
