Results from changing my tranny oil to SWEPCO 201, Comments on transmission oil. |
steuspeed |
Dec 18 2011, 07:20 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
So I have had my car about 6 months now. It has 105k on the clock. No record of when the last time the transmission oil was changed. First and second gear syncros are toast, but if I am real careful I can get it to slip in without grinding. Got to put it in first just before you come to a stop. I just changed the oil (Brad Penn) and thought it would be a good time to try some SWEPCO 201 in the transmission. The oil that drained out looked pretty good. Still had an amber color to it but a little on the low side. So now with the SWEPCO 3rd has a real notchy feel to it. second will zip on the teeth as I come down from third with my usual methods. First is even more finicky than before. Outside Temp is 35-45 degree range right now. Will this get better over time? Seems like I went backwards. (IMG:style_emoticons/default/sad.gif) Any comments welcome.
earossi |
Dec 20 2011, 05:34 PM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
I agree with Casto. I have a 993 and have found that using a trans oil with friction moifiers in it does not work well with Porsche synchros. Many 993 folks have found that an oil like Redline 75W90 N.S. which is a synthetic that does not contain any friction modifiers works best. Many transmission guys working on Porsches will guide you away from Swepco for that reason. So, suggest that you look for an oil without any friction modifiers in the formula.
J P Stein |
Dec 20 2011, 08:46 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I agree with Casto. I have a 993 and have found that using a trans oil with friction moifiers in it does not work well with Porsche synchros. Many 993 folks have found that an oil like Redline 75W90 N.S. which is a synthetic that does not contain any friction modifiers works best. Many transmission guys working on Porsches will guide you away from Swepco for that reason. So, suggest that you look for an oil without any friction modifiers in the formula. You haven't got "Porsche snycros" in your 993. |
Lo-Fi Version | Time is now: 24th May 2024 - 11:25 AM |
