Results from changing my tranny oil to SWEPCO 201, Comments on transmission oil. |
steuspeed |
Dec 18 2011, 07:20 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
So I have had my car about 6 months now. It has 105k on the clock. No record of when the last time the transmission oil was changed. First and second gear syncros are toast, but if I am real careful I can get it to slip in without grinding. Got to put it in first just before you come to a stop. I just changed the oil (Brad Penn) and thought it would be a good time to try some SWEPCO 201 in the transmission. The oil that drained out looked pretty good. Still had an amber color to it but a little on the low side. So now with the SWEPCO 3rd has a real notchy feel to it. second will zip on the teeth as I come down from third with my usual methods. First is even more finicky than before. Outside Temp is 35-45 degree range right now. Will this get better over time? Seems like I went backwards. (IMG:style_emoticons/default/sad.gif) Any comments welcome.
J P Stein |
Dec 22 2011, 01:28 PM
Why are you such a dick? (IMG:style_emoticons/default/confused24.gif) Big Frog? Do you deny that your use is far from the usual? I did the conversion (and trans) in 1998 and took the car off the road in around 2005 so it's about 50-50 but.... my maintenance is far from the 914 usual it seems. When anything started to act unusual I fixed it. The trans has required none of these steps past the "usual" (initial) sorting out the linkage bits....it seems many folks don't even do that. As I've wrote before, I give credit to the trans builder for this success and it has lived far beyond my expectations. All I did was treat it as gently as possible...under the circumstances..... which are well beyond your experience, I believe & keep it full of Swepco.......of course you discount all this and start name calling, Doc. I am not a trans expert. The trans is just another link in the chain and has to be dealt with like any other sub-system of a car.....so I learned to deal with it. I'll have to go back and look at all this thread but I think my only "recommendation" was "just use it" to someone that already had some Swepco. The rest was recounting my experiences with the stuff and letting folks make their own judgments. Bigkensteel.....I'll pass, I reused only my own oil if the urge strikes and I no longer have a 914. I just come here to be a dick. |
SirAndy |
Dec 22 2011, 01:46 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I no longer have a 914. I just come here to be a dick. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 08:14 AM |
