Results from changing my tranny oil to SWEPCO 201, Comments on transmission oil. |
steuspeed |
Dec 18 2011, 07:20 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
So I have had my car about 6 months now. It has 105k on the clock. No record of when the last time the transmission oil was changed. First and second gear syncros are toast, but if I am real careful I can get it to slip in without grinding. Got to put it in first just before you come to a stop. I just changed the oil (Brad Penn) and thought it would be a good time to try some SWEPCO 201 in the transmission. The oil that drained out looked pretty good. Still had an amber color to it but a little on the low side. So now with the SWEPCO 3rd has a real notchy feel to it. second will zip on the teeth as I come down from third with my usual methods. First is even more finicky than before. Outside Temp is 35-45 degree range right now. Will this get better over time? Seems like I went backwards. (IMG:style_emoticons/default/sad.gif) Any comments welcome.
steuspeed |
Oct 23 2020, 02:10 AM
I started this thread and I can confirm SWEPCO is a bad idea in vintage transmissions. Go with the old factory spec non synthetic 90wt hypoid gear oil. It's hard to find. It will be the cheapest on the shelf, but it works. The new stuff is too slick for the syncros to work properly. Once you put SWEPCO in it will be contaminated. It will take several oil changes to get it cleaned out.
Lo-Fi Version | Time is now: 24th May 2024 - 04:42 PM |
