In Need of some assistance!, 914-6 conversion! |
Mr_Chu |
Aug 20 2004, 11:54 AM
Member Group: Members Posts: 58 Joined: 20-August 04 From: Bay Area, CA Member No.: 2,584 |
I currently have a 74 914 2.0-liter. I also bought a 78 911sc recently. What I plan to do is to drop the 915 tranny and the 3.0 liter SC motor into my 914 to give my baby more of a punch. I know I have to do the suspension, brakes, yadda yadda.
But here's the problem I'm having. I talked to a porsche mechanic here and he claims that the 915 tranny won't work in the 914. Is this true? Or is he blowing smoke? I know that the V8 conversions sometimes use 915 tranny's. And if I use the 915 tranny, do I need a rebuild? About how much will it cost? But anyway.. I have more questions to follow. Another problem I have is how to fit the motor in the 914. Does everything bolt in? Or do I need to cut and weld? The wiring is another nightmare I am having right now. Do I need to re-do ALL of the wiring in the car? This project is giving me headaches! Any comments or suggestions will be appreciated! |
736conver |
Aug 20 2004, 12:03 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
I dont have time to tell you everything but I am sure someelse will. Check out the resources section on this board for alot of the parts.
http://www.914world.com/bbs2/index.php?act...t=ST&f=4&t=4315 If you plan on using the 915 you need to flip the R&P. |
seanery |
Aug 20 2004, 12:04 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
The 915 will work in a 914. It just needs the R/P flipped to work correctly.
the 3.0 will need some parts to fit correctly in your car. You will need: -6 Motor Mount (Richard Johnson's is the mount of choice) -6 Sheet Metal (lots of options there, steel or fiberglass) -6 Oil Tank (factory are preferred, but others use aftermarket) -6 Heat Exchangers or Headers -6 Oil Lines There's more, but that's off the top of my head. If it's CIS, some cars had to modify the engine/trunk firewall with a notch to fit. (my 2.7 had that done) Good Luck. Read around here, there is a lot of info in the older threads. |
Lo-Fi Version | Time is now: 28th May 2024 - 04:39 PM |
