OT: Working on my shop car, The wagon Porsche never built. . . |
aircooledtechguy |
Dec 23 2011, 07:20 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I've had a long term project going now to turn my '67 Squareback into my shop car. While I love driving my 914, it has limitations as a daily parts hauler. I love old styling with new technology and updates, so my goal is to turn my humble Square into the wagon that Porsche never made. I want it to drive and handle more like a Porsche than a VW wagon and it's got to be a true "Sleeper" (not a real problem; since it's a wagon). (IMG:style_emoticons/default/shades.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689630.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689631.2.jpg) This has been a 4-5 phase project. Phase-1 - Convert it to Porsche 914 2.0L motor. Make it physically adapted to the car and running MS2 w/ Ford EDIS ignition. Get it tuned to be a daily driver. DONE!! (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689631.3.jpg) Phase-2 - Make the motor look good and freshen it up with new P&Cs. The heads were freshened only about 2K miles before I got it, by me when it was in a clients 914 that he converted to Subie power. I noticed that once I had a few miles on it myself, it was using a bit of oil. So I upgraded to a new set of 96mm P&Cs. So now it's a 2056. I had my local powder coater do all the tins in black and the plenum and runners in grey for a stock look. I'm running T-4 H/Es with a modified bus header and a Summit Racing Flow Master clone muffler. So I had those ceramic coated in black so they are not attention grabbers from the back. This car is a sleeper (IMG:style_emoticons/default/happy11.gif) DONE!! Phase-3 - Convert the rear suspension to the later style IRS and install a Porsche 923 trans out of a Porsche 912E. The rear suspension is DONE!! While at it, I upgraded it with 914 rear brakes, urethane bushings, adjustable spring plates and a rear sway bar. (IMG:style_emoticons/default/driving.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689632.4.jpg) Since the trans is taller than a stock 4-speed and cutting into the car can't happen due to rear seat issues. I gained the 1.5" I needed by spacing the body off the rear suspension with spacers. So here I sit, on the final leg of phase-3. I now need to couple the motor/trans and lift it into it's final place and fab rear engine hanger mounts for the rear bar. It's late and I'm tired. . . Phase-4 - Front suspension upgrade. Currently in-work Phase-5 - Paint so it doesn't look so crappy, though it does add to the "sleeper" persona. . . Stay tuned for more later. . . |
aircooledtechguy |
Sep 27 2012, 09:05 AM
One thing that consistently bugs me about ALL A/C VWs is that there are no cup holders in the car. Typical aftermarket one-size-fits-none solutions generally suck and are flimsy. The Squarsche needed a set, so I came up with these (after seeing sixnotfour's cool drink cup), which could be the words fastest cup holders. (IMG:style_emoticons/default/biggrin.gif) I made them out of a pair of un-usable Porsche 911 Nikasil-coated Aluminum cylinders. I first TIG welded them together, added a piece of pinch-welt to the base (from an old set of beetle pop-outs I had) and then mounted them to a bracket I welded to the tunnel to keep them from moving around while driving. They fit a large McDonald's coffee (Mmmmmmmm. . .) great as well as any of the drink cups.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1348758346.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1348758347.2.jpg) |
VaccaRabite |
Apr 3 2013, 12:22 PM
En Garde! Group: Admin Posts: 13,442 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
...Porsche 911 Nikasil-coated Aluminum cylinders. I first TIG welded them together, added a piece of pinch-welt to the base (from an old set of beetle pop-outs I had) and then mounted them to a bracket I welded to the tunnel to keep them from moving around while driving. They fit a large McDonald's coffee (Mmmmmmmm. . .) great as well as any of the drink cups. I was thinking about this today. Wouldn't this set up effectively make hot drinks cool and cold drinks warm a lot faster then usual? After all, those jugs are made to shed heat quickly. Zach |
aircooledtechguy |
Apr 3 2013, 03:18 PM
I was thinking about this today. Wouldn't this set up effectively make hot drinks cool and cold drinks warm a lot faster then usual? After all, those jugs are made to shed heat quickly. Zach You're way over-thinking these cup holders. . . (IMG:style_emoticons/default/poke.gif) |
Lo-Fi Version | Time is now: 12th May 2024 - 03:01 PM |
