Unknown oil fitting? |
lmcchesney |
Aug 22 2004, 04:58 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
I put the engine back in and cranked it over following the rebuild. I found significant oil leaking/draining from behind the impeller housing. I ended up pulling the enginen out and looked at the source, thinking I did not get the oil in and out barbed fittings tight. To my suprise, I found a fitting hole which I cannot remember what its purpose is. I believe this to be the source of oil loss.
This is a modified 2.0L. We run an external oil cooler in series with our stock oil cooler. Denny removed the stock oil filter mount and capped it off with a plate. He plumbed the case for _8 fittings for oil in and out to the external oil cooler and remote mounted oil filter. Attached image(s) |
lmcchesney |
Aug 22 2004, 05:00 PM
Close up view.
Attached image(s) |
machina |
Aug 23 2004, 05:23 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Here's what mine looks like...
You got a hole there. (IMG:style_emoticons/default/confused24.gif) Maybe its a bus case. dr Attached image(s) |
ChrisFoley |
Aug 23 2004, 05:34 AM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You'll never develop oil pressure that way, lol.
Put a SS plug in it, looks like 3/8" NPT. |
machina |
Aug 23 2004, 05:37 AM
What is it doing there? Looks like its the boss is cast into the case.
While we are talking about leaking oil, what should I use on the NPT nipples, joint compound or is teflon tape OK? dr |
Jake Raby |
Aug 23 2004, 07:22 AM
Someone drilled that galley and tapped it. Just plug it off, like Chris says.
The oil filter blockoff looks inverted or put on backward, it should look like synthesis' does. Synthesis, don't get teflon tape around those use permatex 56521 teflon paste. put nothing on the areas where the AN fittings meet another AN fitting, they are designed to seal without a sealant. |
Allan |
Aug 23 2004, 10:25 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I wish I had a clean engine. (IMG:style_emoticons/default/biggrin.gif)
groot |
Aug 31 2004, 06:25 AM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
I'm using a remote oil cooler adapter that I really don't like. It sends the oil lines straight up from the old cooler location and they interfere with rotating the distributor to time the engine.
I see the solutions posted here and I'm intrigued. A simple blockoff plate for the oil filter is nice, can I do the same for the stock cooler? Also, it looks like you gentlemen have NPT fittings in the front of the block. Did you tap these yourself or are they already there? I didn't look real close at that area when the engine was out. |
machina |
Aug 31 2004, 06:43 AM
Watch those long extensions on your oil ports. All those connectors and adapters in series are like a long lever that will tear your motor up with extreme motor vibration. Since I couldnt fit any AN fittings past the pump plate, I had the local hydraulic shop make these short hoses that go directly to the case port return and the pump plate outlet.
I will attach the AN lines to the ends of the short hoses, makes it easier to reach once the motor is in the car too. The return port was tapped into the case and the outlet is part of the billet pump plate on the front of the motor. dr Attached image(s) |
groot |
Aug 31 2004, 10:45 AM
Cool setup.
I have flex lines going to the remote cooler adapter, so the "long extention" problem should bother my setup, but they're in the way of the distributor. dr, are you on the track yet? I ran a race (test session for me) at Waterford Hills this weekend. Learned a lot. |
machina |
Aug 31 2004, 10:58 AM
QUOTE(groot @ Aug 31 2004, 12:45 PM) dr, are you on the track yet? I ran a race (test session for me) at Waterford Hills this weekend. Learned a lot. Trying to get the motor set-up. Hard to find time during the week. dr |
Lo-Fi Version | Time is now: 26th May 2024 - 09:16 PM |
