> pressure in gas tank- went to fill up- just put tank back in,, why?
DRPHIL914
post Dec 30 2011, 11:01 PM
Dr. Phil
I pulled the tank to get at fresh air blower., put it all bak together, so I ran down to the station to fill up. Had about a gallon and a half in the tank. Went to take the gas cap off, and there was a lot of suction on there. I only drove about10 miles to the station. And it's noit hot out. This is a 75 2.0 with d-jet. The only thing I can think of is that when I put the tank back in the vapor line got pinched .. is it possible this caused the negative pressure that fast. ? And if so can I just leave it disconnect the expansion tank until the tank level is low enough to lift ip to move the vapor line. ?
Phil
Mike Bellis
post Dec 31 2011, 01:39 AM
Resident Electrician
I crushed a tank once (not in a 914). The vent/vapor line was plugged. It does not take long for it to happen.
post Dec 31 2011, 10:28 AM
pull the cover from below (4 bolts) and you might be able to access any pinched lines and correct.
Bob L.
post Dec 31 2011, 07:37 PM
Don't mean to hijack, just seems relevant...
Mine was converted to a carb (yes, singular) by PO. He plugged the return fuel line. So, basically there is just the fuel line out.
Is this going to be a problem?
Is my tank going to crush?!?!
BMITCHELL
post Dec 31 2011, 07:48 PM
It still should be vented. Vent line on expansion tank going to the filler neck.
Elliot Cannon
Group: Retired Members
QUOTE(Bob L. @ Dec 31 2011, 05:37 PM) *
My car has carbs and a blocked off return line. I think what they're talking about here is the "vent" line. It's a small line coming off the fuel cap I believe.
Bob L.
post Dec 31 2011, 08:23 PM
QUOTE(Elliot Cannon @ Dec 31 2011, 07:48 PM) *
Then I'm good.
This site is like reading a medical text book... every time I read about someones problem, I start to worry I have it too.
Thanks, now I can (IMG:style_emoticons/default/gint2.gif)
P.S. Happy New Year!
Racing916
post Dec 31 2011, 08:47 PM
I race my 914 with a 6 cylinder and the return capped off. If it is vented it should not have pressure built up. Make sure your vent line in not plugged.
rgalla9146
post Jan 1 2012, 08:26 AM
QUOTE(Racing916 @ Dec 31 2011, 06:47 PM) *
Many years ago I had a factory slant nose Turbo in my shop with an inop. fuel level gauge.
You guessed it, blocked vent caused pump ( pumps ! ..Turbo ) to suck that tank down so that it looked like it had been used to wrap your leftover sandwich.
DRPHIL914
post Jan 1 2012, 10:00 AM
Dr. Phil
QUOTE(rgalla9146 @ Jan 1 2012, 09:26 AM) *
Is it possible that my charcoal filter is clogged or blocked? The plastic line runs from the relief tank back to the charcoal filter. I need a diagram of what and how the hook ups go on the filter too.
May be the charcoal filter needs to be replaced?
Just another thought
Mike Bellis
post Jan 1 2012, 11:59 AM
Never seen a charcol filter clogged but anything is possible.
Check out Jeff Bowlsby's site... http://bowlsby.net/914/Classic/
- Lo-Fi Version Time is now: 9th February 2026 - 11:06 AM
