> Wheel spacers, doesn't make sense???
retrotech
post Aug 24 2004, 12:44 PM
retrotech
Help.
I have been on this topic prior to fitting wheels, but the numbers don't make sense. I am using 17 x 7" 993 wheels with marked off set of 55mm. I have 205 tires mounted. I want to use 215, but everyone says they won't fit.
From the beginning I thought I would need 23mm spacers, but I just tried some 1/4" spacers that were laying around and they work.
On the front with 1/4" there is slight rub on full lock, at front of tire, with 1/2" none.
On the rear with 1/4" there is a closer fit 1/4 - 3/8" at the top inside, with tons by the fender lip, that has been rolled.
With 1/2", just the reverse as above. It almost looks like I could use 215's. But how can this work with only 1/4 & 1/2" spacers.
Anyone with a similar application to advise on there spacer size?
Retro
- Lo-Fi Version Time is now: 12th July 2025 - 06:56 AM
