Chassis Stiffening, should I? |
Woody |
Jan 3 2012, 04:28 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
So I bought the 10 piece chassis kit and the trailing arm box kit and the car is prepped for install. My car has never had any rust issues and looking at the bare metal everything looks great. I can't find any cracks or any other irregularities. The car is autocrossed at least monthly and I am attempting to stiffen it up. I will fab up a inner ear brace as well and rollbar is in the works too. Well I started browsing and I guess some of you guys don't like the 10 piece kit. Should I just leave it off and stitch weld all the body seams instead? What about the trailing arm box kit? Am I going to be adding weight that isn't going to benefit anything?
neilca |
Jan 4 2012, 08:23 AM
Member Group: Members Posts: 98 Joined: 26-July 05 From: Marietta, GA Member No.: 4,474 |
I do not run it in road racing, too heavy. I also do not have enough talent to feel flex in my trailing arms.
The 914 has a spot weld about every 1/4 inch on the body seams. I know cause I had to drill them out. I do not think welding the seams will get you anything and the foam in between the panels will catch on fire. Cage is the best way to stiffen the chassis and it protects the driver too. Good luck, |
Woody |
Jan 4 2012, 11:25 AM
I do not run it in road racing, too heavy. I also do not have enough talent to feel flex in my trailing arms. The 914 has a spot weld about every 1/4 inch on the body seams. I know cause I had to drill them out. I do not think welding the seams will get you anything and the foam in between the panels will catch on fire. Cage is the best way to stiffen the chassis and it protects the driver too. Good luck, I was unaware that there is foam in between the panels. I was looking at it last night and I think I would be more inclined to stitch weld the trailing arm mounts and leave the rest alone. Thanks. |
Lo-Fi Version | Time is now: 19th May 2024 - 11:08 PM |
